explorer intake vacum setup help!
  • Thread starter Thread starter mob
  • Start date Start date Sep 9, 2006
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Sep 9, 2006
  • Sep 9, 2006
Hey guys im going to try to install my intake myself tomorrow. Can you guys help me out real quick. Maybe draw a diagram in paint. This is what ive figured out, but I know it cant be this easy because i was told I have to do some changes and fittings and such. HELP???
This is what I think so far.
1 goes to PCV
2 goes to the carbonl canister
3 i have no idea
4 i have no idea
5 do i need to plug that?
bryce93lx
88
Luke AFB AZ
Sep 9, 2006
  • Sep 9, 2006
http://www.allfordmustangs.com/Detailed/614.shtml
found it on google, i didn't read it but it looked pretty good, it should help
mob
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Sep 9, 2006
  • Sep 9, 2006
i have that on favorites but still dosent tell me where the vacumm lines go..
mob
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Sep 9, 2006
  • Sep 9, 2006
oh and ive read jritckers write up, I still dont know what line goes where though. Any help would be appreciated, im not sure if im going to be able to do this.
71swing
199
Omaha,NE
Sep 9, 2006
  • Sep 9, 2006
3 can be plugged
4 needs to go to the fuel regulator
5 should have a vacum tree in it that goes to the map sensor if its (speed density), and the vacum tree on the firewall
mob
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Sep 9, 2006
  • Sep 9, 2006
71swing said:
3 can be plugged
thats perfect, now for number 5, if it is MAF is it just one hose to the vacuum tree on the firewall? and it goes to the "souce" plug right?
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Sep 9, 2006
  • Sep 9, 2006
just make sure your brake booster, FPR, PCV anf vac canister are getting vac, doesnt matter where and anything else u dont use you can plug
mob
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Sep 9, 2006
  • Sep 9, 2006
alright i have a question, number 5 is broken off, can i make a tree on number 4 and run it to the fpr, source, and that other small black vacuum? Will it pull enough vcauum? This is very important because if it does not then i will have to get something put in where number 5 is and that will be a big pain. So if i can make a tree thing and run 4 to the fpr and tree then that would be great.
90_Red_LX
668
Asheboro, NC
Sep 9, 2006
  • Sep 9, 2006
Agreed. When I done my swap I pinched my line so when I took it out I had to make a loop because I had no power brakes. Not fun.
T
TheUser
1,859
Springfield, MO
Sep 9, 2006
#10
  • Sep 9, 2006
  • #10
I don't think that little line would be good for all that vac - just my opinion.
I'd shoot the small one to the FPR and the vac tree from the pass fenderwell.
The way I see it, you have a few options for the vac distribution block on the firewall (brakes, etc).
1) Use the hose that goes from the PCV fitting to the front of the intake and plug the port on the front of the intake when you unplug that hose. You may have to purchase a new hose, but use that fitting. You get the idea...
2) Run a hose from 3 around to the vac distribution block on the firewall. I suppose you could cut it off where it would go straight down instead of facing forward and use a hose clamp to hold it on.
3) Do what I mentioned above to number 2.
4) Get a fitting put in 5 and run it to the vac. distribution block on the firewall.
mob
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Sep 9, 2006
#11
  • Sep 9, 2006
  • #11
im not quite sure what all that means. I know i have to connect 5 things. fpr, carbon canister, "source" on vacuum tree, pcv, and a small black plastic hose. Will this work? plug pcv in no problem. get a fitting for 5 and run that to the "source" on vacuum tree firewall, and get a double thing and run the small black hose, and fpr to 4? and then connect carbon cannister to 2, and plug 3. Or better yet, can i do all of that but put the source to 3, and plug 5 so i dont have to get a fitting?
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
Engine Explorer - Lower intake internal cleaning
  • R82148V
  • Nov 11, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Dec 6, 2025
rednotch
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
