explorer intake vacum setup help!
mob
the guy who hits on his mom
Oct 3, 2003
2,566
136
104
Dallas, TX
Hey guys im going to try to install my intake myself tomorrow. Can you guys help me out real quick. Maybe draw a diagram in paint. This is what ive figured out, but I know it cant be this easy because i was told I have to do some changes and fittings and such. HELP???
This is what I think so far.
1 goes to PCV
2 goes to the carbonl canister
3 i have no idea
4 i have no idea
5 do i need to plug that?
oh and ive read jritckers write up, I still dont know what line goes where though. Any help would be appreciated, im not sure if im going to be able to do this.
71swing said:
3 can be plugged
4 needs to go to the fuel regulator
5 should have a vacum tree in it that goes to the map sensor if its (speed density), and the vacum tree on the firewall
thats perfect, now for number 5, if it is MAF is it just one hose to the vacuum tree on the firewall? and it goes to the "souce" plug right?
alright i have a question, number 5 is broken off, can i make a tree on number 4 and run it to the fpr, source, and that other small black vacuum? Will it pull enough vcauum? This is very important because if it does not then i will have to get something put in where number 5 is and that will be a big pain. So if i can make a tree thing and run 4 to the fpr and tree then that would be great.
Foxfan88 said:
just make sure your brake booster, FPR, PCV anf vac canister are getting vac, doesnt matter where and anything else u dont use you can plug
Agreed. When I done my swap I pinched my line so when I took it out I had to make a loop because I had no power brakes. Not fun.
I don't think that little line would be good for all that vac - just my opinion.
I'd shoot the small one to the FPR and the vac tree from the pass fenderwell.
The way I see it, you have a few options for the vac distribution block on the firewall (brakes, etc).
1) Use the hose that goes from the PCV fitting to the front of the intake and plug the port on the front of the intake when you unplug that hose. You may have to purchase a new hose, but use that fitting. You get the idea...
2) Run a hose from 3 around to the vac distribution block on the firewall. I suppose you could cut it off where it would go straight down instead of facing forward and use a hose clamp to hold it on.
3) Do what I mentioned above to number 2.
4) Get a fitting put in 5 and run it to the vac. distribution block on the firewall.
im not quite sure what all that means. I know i have to connect 5 things. fpr, carbon canister, "source" on vacuum tree, pcv, and a small black plastic hose. Will this work? plug pcv in no problem. get a fitting for 5 and run that to the "source" on vacuum tree firewall, and get a double thing and run the small black hose, and fpr to 4? and then connect carbon cannister to 2, and plug 3. Or better yet, can i do all of that but put the source to 3, and plug 5 so i dont have to get a fitting?
