explorer intake
Sn95stang_302 said:
i have a bbk 70mm throttle body and trick flow adapter and i was wondering if a explorer intake is a worth while mod or if i should just get a non-ford one?
If you have stock heads, then the Explorer will work fine because it flows more than your heads anyway. Its just not the best looking intake. :D
It depends on how much you can get one for. Search your area junk yard for the 96(?) explorers 5.0 and see what you can find cheap. Also a good cheap upgrade are the explorer heads ( gt40-p casting) they are on the same engines that the intakes come on.
is there anything special you have to do or buy to use an explorer intake on a 94-95 gt?, also is the explorer intake manifolds equivelant to the cobra intake? if not what is it equivelant to? i am thinking about getting one, thanks
yea but i could get an explorer one from a junk yard for very cheap , im on a tight budget, anyone know if i can use my stock strut tower brace with this intake?
You will also need a 94-95 intake adapter. They retail for about $100, but I think you could find one in the classifieds for a good price. I believe any brand adapter will work. Then you will need some new gaskets and some vacuum hose. It was really easy to install mine.
I noticed a seat in the pants difference with it. I'm not shure how much you could find one for at a jy. I paid $225 new from a shop that got some new ones a few years ago. I'm not shure on the year but you could do a search on this board in the 5.0 area and see what comes up. I think they they where around the 96-97 time line And they might be eddie bauer packages but i'm not sure. The intake plaque says 5.0 right on it.
I think I needed a piece of hose to run on a spot on the intake. Installing the intake will be really easy. It was the first mod I did to my car when I was 17 and never really done to much on car engines before that. If you goo the top of the 94-95 tech page look at 94-95 FAQ and there is an intake install guide there and that will show you what's involved with an install.
