Explorer MAF on Fox
  • Thread starter Thread starter Chrome_Rust
  • Start date Start date Aug 20, 2009
Chrome_Rust
530
Findlay, Ohio
Aug 20, 2009
  • Aug 20, 2009
well last year I tore my stang apart for the wiring harness swap, and to install the SN95 dash and what not. During that time i had a bunch of parts stolen. Namly a rebuilt T5 (2.95 1st), MSD 6A, Blaster 3 Coil, UDP's My tweecer, and a Pro Flow 77mm MAF. I have all the parts nessessary to put the car back together to run now, but the MAF is what i am still lacking. I have a 70mm ( I think) from a 2000 explorer. I have the pigtail from the same vehicle, can i use tat MAF or am i way in left field? thanks! Oh, the engine is going to be a stock 302, stock cam, 1.7's, 1 5/8" shorty's, 2.5" flows, UDP's. Controlled by my A9L.
Thanks!
Charlie
HISSIN50
34
129
Aug 20, 2009
  • Aug 20, 2009
Since you have a TwEECer, you should be able to tweak the transfer curve to get it to work.
Chrome_Rust
530
Findlay, Ohio
Aug 20, 2009
  • Aug 20, 2009
I HAD a TwEECer... It was ripped off along with the other parts.
Do you think that it will throw it WAY off? I was just going to use it to get it running. not put any miles. the car is completely apart.
HISSIN50
34
129
Aug 20, 2009
  • Aug 20, 2009
Go into a tuning site and compare the transfer curves for both. Based upon what people in the past have posted, it very well might run ok (enough to move the car around or let it idle).
Chrome_Rust
530
Findlay, Ohio
Aug 21, 2009
  • Aug 21, 2009
ok I'll give that a shot!
vristang
4,933
101
124
Seattle
Aug 21, 2009
  • Aug 21, 2009
If you are running stock 19's then maybe....
Post ALL the numbers on the sensor and post a pic of the housing if you can
If you know the catch code of the explorer ecu, then you should be able to find the transfer function
Chrome_Rust
530
Findlay, Ohio
Aug 21, 2009
  • Aug 21, 2009
i do have the ECU, at a buddy's. I will get a pic here later on. thanks for the help!
  • dan50
  • Jul 18, 2026
dan50
help me understand calibrated maf sensors and injectors
  • stackz
  • Sep 21, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
AeroCoupe
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Idle spark confusion
  • sav22rem22
  • Oct 26, 2023
  • Digital Self-tuning Forum
2K
Digital Self-tuning Forum Nov 1, 2023
sav22rem22
P
Thoughts on this odd (smog legal) combo?
  • PJV9126
  • Feb 8, 2023
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 16, 2023
91AOD5.0LX
