Explorer TB TPS HELP!
91foxbodygt
76
i got my explorer tb on. its off a 96 explorer, and i used the tps off my mustang. Just installed yesterday; now it idles off, most of the time its ok, but its turned off twice on me once maybe at 5mph and the other time at a stoplight.
am i supposed to use the explorer tps with the mustang harness connector? i read somewhere i had to grind the tab at the end of the explorer throttle body shaft but the mustang tps fit perfectly without any modification.
any help is greatly appreciated, thanks
btw, i havent checked the tps voltage
I used an after market TPS and it fit perfectly.
If that isn't a good option for you, then the Explorer TPS connector shell can easily be disassembled and the pins/wires removed. The original Mustang TPS connector shell comes apart in the same manner. Make a drawing of the Mustang TPS connector wire colors and what socket they go in before you get started. A safety pin or jeweler's screwdriver is used to extract the red insert from the front of the connector shell. Once the red insert is out, the pins with the wires will slide out the back of the connector shell. Put the Mustang TPS connector shell on the Explorer TPS assembly pins/wires and put the red insert back in. Install the modified TPS, set the base voltage and you are in business.
Try this... Currently there is some dispute about setting it at .99 volts being worth the effort, but anything less is probably OK. All you need is less than 1.0 volt at idle and more than 4.25 at Wide Open Throttle (WOT). You'll need a Digital Voltmeter (DVM) to do the job.
The Orange/White wire is the VREF 5 volts from the computer. You use the Dark Green/Lt green wire (TPS signal) and the Black/White wire (TPS ground) to set the TPS
Here’s a TPS tip I got from NoGo50
When you installed the sensor make sure you place it on the peg right and then tighten it down properly. Loosen the back screw a tiny bit so the sensor can pivot and loosen the front screw enough so you can move it just a little in very small increments. I wouldn’t try to adjust it using marks. Set it at .97v-.99v, the closer to .99v the better.
(copied from MustangMax, Glendale AZ)
1. Always adjust the TPS and Idle with the engine at operating temp. Dive it around for a bit if you can and get it nice and warm.
2. When you probe the leads of the TPS, do not use an engine ground, put the ground probe into the lead of the TPS. You should be connecting both meter probes to the TPS and not one to the TPS and the other to ground.
3. Always reset the computer whenever you adjust the TPS or clean/change any sensors. I just pull the battery lead for 10 minutes.
4. Check the procedure for your year, on my 90 I have to turn the idle screw until it just touches the tab, then insert a .010 feeler gauge and give it about one more turn. Then you adjust the TPS voltage to .98v, reset the computer. Start it up, if the idle is to low then turn the screw in until it is just right, then readjust the TPS voltage to .98v and reset the computer and start it up. The key is to adjust the TPS voltage and reset the computer whenever the idle screw is changed.
