- Jun 11, 2004
- 41
- 2
- 8
I recently purchased a McLeod scattershield to put in along with the TKO600 I'll be installing. From searching on here, I've been under the impression that an extended clutch fork is needed when using a scattershield. What makes me wonder is that the guy I ordered the shield from told me that I didn't need one, and that he's been running the same shield for 4 yrs without a problem. Can anybody tell me for certain if I'll need one or not? Also, how will I know if I need an adjustable clutch fork pivot ball? Thanks!
You talked to the guy at D&D and you are correct ... he does not have an extended fork. However, you will like your setup much better with the extended fork. It like saying you don't have to have a transmission with synchros either but it makes everything a lot easier when you do. I highly suggest you pick one up to avoid all sorts of cable issues and added pedal pressure.
