I understand the need for an FMU in that circumstance however, it's the result of your injectors being too small for the combination. My point is that if you're going to recommend that someone get new injectors for a blown combo, then why not get injectors large enough to handle the job? Particularly if you're also recommending a custom tune.
On the meter thing:
Droves of folks mistakenly think that stock meters are calibrated specifically for 19 lb injectors. That is not the case. It's actually the EEC program that makes the determination of whether or not a meter is in correlation with a given set of injectors. Calibrated meters for X sized injectors are a "work around" developed to use the fuel ramps and tables already in the EEC. If a custom tune is obtained, then those fuel ramps and tables can be properly entered into the EEC so that the correct amount of fuel is given per volume of air. So long as the inducted air volume does not "peg" the meter then it's perfectly acceptable to use the stock meter for the application, particularly when the stock sized throttle body is used (since the throttle body will be the induction bottle neck and not the meter).
It's nuances like this that can either cost or save somone from spending money on things that are not required. The money saved on injectors and meter alone would pay for a good wide band 02 meter.
Just a thought.
