i finnished my first project early today so i leveled it up and checked it for square .the driver rear frame rail was 1/2 inch low at the very end.i braced a
2x6 from the trunk devider over the frame rail to the roof of my car port and jacked the rail up untill it stayed level all by its self ,you will not believe how easy the frame rails bend when they are bare. the rear trunk brace went in first,41 1/2 "between the rails with 4 1/2 "haing past the frame rails at both sides of each rail . the pass.side trunk floor went in with ease i traced the frame rails on the bottom of the floor and removed it and drilled for plug weld holes replaced it and welded it in. the pass. wheel tub was next . line the tub up on the inside with the inner tub not the outside flange or it will not be right. i left the rear tail un welded so i can line it up in the quarter a litle easier then i will plug weld it from the inside after the quarter is on. did the same with the driver floor as the pass. floor that was about as far as i got today.i will finnish the driver side tomarrow.
it's hard to hand them over after all of this . it will be back though still have the floor and front aprons to go. and i will be fitting a 67 shelby fiberglass kit on it. by by for now
