F-cam??
  • Thread starter Thread starter AllOut84
  • Start date Start date Jan 25, 2009
A
AllOut84
Bridgeton,NJ
Jan 25, 2009
  • Jan 25, 2009
I got a ford racing F cam for pretty much nothing while im in the progress of building my 351 im gonna throw on ported gt-40 heads on my stock short block w/1.6 roller rockers and im wondering if the F cam is even worth putting in vs the stock cam I run 125 shot of the wet sauce and its a stick car also w/ explorer gt40 upper n lower intake with full exhaust.
Just wondering if this cam will benifit with my set up.
Thanks
88mouse
630
Mooresville nc
Jan 25, 2009
  • Jan 25, 2009
I can't help you with the cam.
But just in case. You know your explorer intake isn't going to work with the 351?
KamiKaziDK
555
Mesa, Az
Jan 25, 2009
  • Jan 25, 2009
Headers aren't gonna swap over either....... F is a little steep for that combo, cause even with the 351 I imagine you're only gonna put out a little over 300 at the crank maybe depending on porting etc....Try and find something with better low end tq/hp than the f-cam I would say....just my 2c
A
AllOut84
Bridgeton,NJ
Jan 25, 2009
  • Jan 25, 2009
The 351 is getting a solid hydraulic cam, vic jr upper n lower and some stroked internals.
I want to put the F-cam in my stock 302 just curious if it will benifit with my current set up gt40 heads gt40 intake and spray or should I keep my stock cam
KamiKaziDK
555
Mesa, Az
Jan 25, 2009
  • Jan 25, 2009
stick with stock....ebay the F and make some cash for the 351. You might get 10hp out of cam swap
V
vadim
57
  • Jan 25, 2009
only 10HP over Stock cam? seems awfully low.
KamiKaziDK
555
Mesa, Az
Jan 25, 2009
  • Jan 25, 2009
Yeah, I meant total. I'm sure some peak numbers will be up in the 20+ hp gains....but bottom end is gonna go out the window, and the heads and intake he has aren't big enough to take advantage of the big cam...but that's just my guess since I don't know the porting on the heads and what not. Are the springs upgraded on the heads also?
57fairlane
560
Oakwood, GA
Jan 25, 2009
  • Jan 25, 2009
It'll pick up more on the spray than the stock cam will thats for sure . . .
A
AllOut84
Bridgeton,NJ
Jan 25, 2009
  • Jan 25, 2009
They are stock springs out of the 94 cobra the heads came off of. They are gasket match ported. Intake is matched to a 1250 fel pro.
My buddy is begging me to sell him this f cam thats the only reason im asking if its worth putting it in.
Thanks for the replies
V
vadim
57
#10
  • Jan 26, 2009
  • #10
yeah, i guess that would make more sence to me know. thanks!
Vadim
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Holley High-ram tuning settings
  • spencergt66
  • Apr 1, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jun 19, 2026
spencergt66
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Engine Prw rockers, trick flow cam, gt40 heads
  • 67fox
  • Apr 15, 2024
2K
Fox 5.0 Mustang Tech Jan 15, 2025
hollywoodstang8
H
