Ok....so this weekend started as finishing welds on my torque box, installing my new KYB shocks and quads in the rear as well as installing some stock upper and lower control arms I picked up with poly bushings installed and putting the tank back in place....and turned into hell. All that stuff took up Saturday because we ran into a bunch of stupid problems with different stuff, but ended up finishing it and the rear suspension is stiffer than my friends 08 Charger R/T
...and I still have to re-install the sway bar. Well today we head back over cause my friend is putting tires on my old ponies and giving me his 10 holes to put on the car cause the wheels/tires I have on it now are shot...well, we run way hot on the way over and take a look.....the freeze plug on the front(thank god!) passenger side head is bad and leaking water, so we pull of all the accessories, yank it, tap in a new one....put her all back together and fire up.....now water is coming out of the back of the engine!! We're pissed cause we don't wanna yank the engine to change a rear freeze plug so I get up under the car and see the water is coming from the middle of the intake where I can't see it, but at least it's not the freeze plug. Anyhow...to make an already really long story shorter, his metal coolant tubes that run along the lower intake rotted through and we had to cut them, grind them down and replace them with heater hose
Never did get the damn tires/wheels swapped out
This story also excludes the 3 hour ordeal of my g/f loosing her mind and trying to run me over with my land rover and the before mentioned dodge charger.
And that's my rant
And that's my rant
NOT! thats the best thing about my g/f not having a licences plus us not living together! i do what i want when i want how i want and where i want! I've learned after my last relationship (of 12 years) no
