I know they are better cams out there but I just wanted to know which one of the 2 sounded better for instance which has meanest sound at idle? Also which makes most power? F 303 or B 303 thanks guys any help is appreciated,RICK
yea ive been through all that except the TPS and the cap and rotor. mine does the same thing with putting it in gear as well, im running a c-4 and when its in gear it just chucks out. maybe i should try the throttle position sensor and an MSD or something??Mine used to do that. But I cleaned the MAF, IAC, set the TPS, made sure the air filter was clean, new plugs, wires, cap, coil, rotor ect ect.
Now I can get it to idle low. However every once and awhile it stalls when I put it in gear. (aode)
