F303 Cam With A 2500 Stall
Bill88Stang
357
Palm Coast FL
Not exactly mustang related but I hope you can help. I'm wondering if a 2500 stall converter would be enough for a f303. It would be in a 94 lighting with a10:1 351 mass add converted running a mustang a9p computer. It currently has a e303 with a 1800 stall and I have the tranny out replacing the converter with a 2500 stall and new front pump. I have the f can brand new and always though the e was on the very small side in the 351. I think the f would work better with the heavily ported Windsor Jr. Heads and the gt40 upper and lower then the e would. Thanks for any input. Please no flames about the alphabet cams it would be a free swap for me.
If you look into the cam card and see what the power range for the cam is, this will give you a ballpark on the low side. Fwiw 2500 stall is what I ran in my aod with a e303 and she pulled hard.
I think Mike has the best advice, but it sounds like you are wanting to use the stuff you already have. The 351 is 14% larger than the 302. In theory, that would bring the 2800 rpm power band down to around 2400, which is right in your ball park. Is this the ideal setup? Probably not, but it should work just fine.
Joe
Reactions: A5literMan
