F4TE Block + 4.25" Stroker Crank?
  • Thread starter Thread starter tjm73
  • Start date Start date Jul 5, 2005
T
tjm73
2,418
Rush, NY
Jul 5, 2005
  • Jul 5, 2005
Anyone put a 4.25" stroker crank in a factory block? Will it fit?
Particularly, I'm curious about clearing the pan rails, the oil pump pick up tube and the cam journal area. I know the bottoms of the cylinder bores would need clearencing.
Rick 91GT
Mustang Master
95
99
PA
Jul 5, 2005
  • Jul 5, 2005
I don't think that will fit, what rod will you use?
Numbles
998
Chicago, IL
Jul 5, 2005
  • Jul 5, 2005
Seems to me you should look for a 351 block to fit that typr of crank it. Could be wrong.
Daniel50
716
Discovery Bay, CA
Jul 5, 2005
  • Jul 5, 2005
not sure on the fitment either since never really heard anyone using it. only one way to find out though
T
tjm73
2,418
Rush, NY
Jul 5, 2005
  • Jul 5, 2005
If it were to be built it would be a 6.200" rod.
My brother has a F4TE block with a 4.10" stroker crank with 6.200" rods in it, so I know that will fit.
bjl95mustang
1,495
Austin,TX
Jul 6, 2005
  • Jul 6, 2005
Search on www.hardcore50.com . The owner of chp postes on there plus alot of engine builders.There has been some talk about the 4.25 cranks in there. You have to worry more about the rod design with the cam than the stroke. My eagle rods are made for a stroker the the cap screws are place so they wont hit the cam.
When I did my 95 roller block and a 4.1 crank I had grind the piston bore a bit and I had to grind a casting mount next to the oil pump, thats it. Get a set of cheap bearings drop the crank in, then sharpie the areas that it hits. Grind then wash you block.
T
tjm73
2,418
Rush, NY
Jul 6, 2005
  • Jul 6, 2005
That is exactly what my brother did with his 4.10" stroke 418W.
Rick 91GT
Mustang Master
95
99
PA
Jul 6, 2005
  • Jul 6, 2005
That is why I asked what rod you plan to run, that has a huge impact along with the cam, (roller bearing, standard, core size).
I've done the 4.1" just like above.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
  • dan50
  • Jul 18, 2026
dan50
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
