Factory brake bracket flaw
Foxmoto28
Has anyone came across the bracket above the drive shaft breaking, causing the brake cable to rub against the drive shaft? And fixed it?
I've been looking for a solution so my cable won't rub against my drive shaft. It isn't bad but it can get there, fast.
If you have came across this, please tell me how you fixed it and if you did anything to it (such as fabricated another bracket or something) please post pictures and share your ideas.
Thanks.
Some say they added some pop rivets to the metal to support it more, but I haven't seen any photos of the fix. Mine was just bent, so I just bent mine back up as high as I could.
I've heard of it but never experienced it. A few things I've heard you can do...
1. Re-weld it back up to the top of the tunnel with a couple spot welds (probably easiest)
2. Rivet it like said above (not as easy, requires a hole or two to be drilled)
3. Drill hole and bolt it back up (same as rivets, but would need access from the top side too)
