Do yourself a favor now before you bend or break something and replace the valve springs. If you don't have the money to have the heads taken to a machine shop and have them checked out, the valves ground and springs replaced, you would be better off to wait until you do have the $$ to do it right.Since I'm on a budget will the stock valve springs work with the stock cam I'm not going to rev past 5200
No, they cant.What I meant was I'm budgeting for parts and I wanted to know if the stock springs could handle the lift
Mac makes garbage that doesn't last and usually has issues lining up.
Just stick with the ford racing p headers, they will go on and off easily.
No you can't re-use them.I'll see when I go Saturday and look for a set. Can I reuse my factory head bolts or are they torque to yield
Yup, there are a couple sets of arp's you can use. Head studs, bolts with reducers, then stepped bolts. I always used the stepped, but they are much more expensive than the ones with washers.So they are torque to yield
