Factory Radio won't work!
swami
hi all,
i just bought my 1994 GT with 51,000 miles and it didn't have a radio. i had a working radio that came out of a 1994 mustang that i bought new. somebody had cut into the factory harness to install an aftermarket radio so i just reconnected and soldered those wires but it won't turn on. i checked the fuses under the dash and in the engine compartment. would a bad factory amp cause this? i plugged in the amp wire harness but didn't check to see if the amp was even there (trunk right?). TIA
I cant help you very much, but I can say that yes, the factory amps for the rear speakers are in the trunk. They're protected by a big black plastic shroud. If you lay on your back in the trunk, you should be able to figure out how to assess the situation back there.
