Failed emissions w/the "B": Hydrocarbons
  • Thread starter Thread starter BYRDPE
  • Start date Start date May 23, 2008
BYRDPE
1,556
Memphis,Tn.
May 23, 2008
  • May 23, 2008
I passed the carbon monoxide portion but failed for hydrocarbons.
Standard is 220ppm...I tested at 988ppm w/o cats.
However, I still have my stock H pipe which I am going to install and test again.
Last year I tested with the same O/R H and the results were:
Standard 220 and I tested 73.98ppm.
The prior year I tested with the stock H and the results were:
Standard 220 and I tested 32ppm.
Anyone think the stock H will get me there?
Any other ideas to help pass?
Thanks
BTW...I already know the "B" is not emissions legal.
LiquidGT
368
Near STL hell
May 23, 2008
  • May 23, 2008
I passed my final test with the set up in my profle (like yours with no s/c) with a Magnaflow catted H, no thermactor system, and a bad TFI that gave me a crappy idle with no access to 3k+ rpm; but they only did an idle test.
I would try to get it to pass with the stock pipe first, make sure you drive the car to operating temps. You could try new O2's, oil change/tune up crap, clean the egr... if you still run it. They also have some stuff called Guaranteed to pass at the parts store. I never used it, but the company will reimburse you for the bottle if the car fails.
D
Deleted member 87397
May 25, 2008
  • May 25, 2008
back your timing down a bit, lower your fuel pressure, add some acetone to your gas 1 oz per 4 gallons. It will cut your hydrocarbons down. The stock H should work well too. As mentioned above though make sure you drive the car for a good while to get the cats nice and hot.
93 LX
3,081
Norwalk, CA.
May 25, 2008
  • May 25, 2008
Acetone?? what does this do??
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
May 25, 2008
  • May 25, 2008
it makes it burn cleaner. when did tenneessee start DEQ? what part of tenneessee are you in? i moved from there in 96 and lived in shelby county (bartlett) and we didnt have it then. peace
john
93 LX
3,081
Norwalk, CA.
May 25, 2008
  • May 25, 2008
Who else has tried this?
LiquidGT
368
Near STL hell
May 25, 2008
  • May 25, 2008
I heard that the acetone is supposed to increase you gas mileage, but they tested it on Mythbusters and proved it to be wrong, I think it was a little worse. I never heard about using acetone for emissions, but if it makes your mileage worse then I would assume it wouldnt help emissions.
I tried running acetone in my escort just because I could, and I didnt see any difference in gas mileage.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
May 25, 2008
  • May 25, 2008
i've never tried it i just heard it burns cleaner? i think it's all B.S. also tho? who knows peace
john
Mustang5L5
Mod Dude
Feb 18, 2001
43,389
18,131
224
Massachusetts
May 25, 2008
  • May 25, 2008
I'm surprised ou passed at all with an off-road H-pipe
D
May 25, 2008
#10
  • May 25, 2008
  • #10
I've run it before. No noticeable gain in mileage, but I did notice all the black sooty stuff that usually accumulates on my bumper all but vanished. It should help with the hydrocarbons enough bring your level down.
loveblueoval
23
Salt Lake City, UT.
May 25, 2008
#11
  • May 25, 2008
  • #11
Go try a bottle or two of rubbing alcohol it lowered my hydrocarbons about 50 to 60 points!!!! I swear.
BYRDPE
1,556
Memphis,Tn.
May 25, 2008
#12
  • May 25, 2008
  • #12
lol...I know a guy that did the same thing and he said it helped him pass.
quote]I tried running acetone in my escort just because I could, and I didnt see any difference in gas mileage. [/quote]
LiquidGT, where can I find acetone?
I'm in Memphis, Shelby County.
fastfox86, I really don't want to mess with the tune if I don't have to. I guess I can record the fuel pressure and put it back and do the same with the timing.
I'm hoping I can find the acetone and use that along with the stoch H.
Anyone know where to find this stuff?
Thanks for the suggestions guys. Now I have a few things to work with.
LiquidGT
368
Near STL hell
May 25, 2008
#13
  • May 25, 2008
  • #13
You can get acetone from anywhere that has a paint section, auto parts stores, wal mart...
It's actually just paint thinner.
93 LX
3,081
Norwalk, CA.
May 26, 2008
#14
  • May 26, 2008
  • #14
I do this all the time. get 90% or higher since the lower stuff has a ton more water in the mix.
D
May 26, 2008
#15
  • May 26, 2008
  • #15
Wal-Mart in the paint section.
stick0014
#16
  • May 26, 2008
  • #16
might help
i have a similiar set up, using edelbrok heads and vortech blower, i also failed on my hc. by alot, you will need the cats and a good O2 sensors, and i actually asdvanced my timing, ran ultra 94 with octane boost, then drove the piss out of the car to get it good and hot. and i passed by 1 point...lol
BYRDPE
1,556
Memphis,Tn.
May 26, 2008
#17
  • May 26, 2008
  • #17
Posted via Mobile Device
Do you remember what nunber it was?
Fast63
717
#18
  • May 26, 2008
  • #18
you will probably pass with the stock H-pipe, but you might pass even more with a new H-pipe with converters.
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
N
help, o2 and cat monitors wont ready for emissions test, 2013 mustang gt
  • nmontalbano
  • Nov 27, 2023
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Nov 27, 2023
nmontalbano
N
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
