HISSIN50 said:Rick My low speed comes on at 208 and goes off at ~200*F.
I can dig through the factory manual if you need an exact spec.
If you are working on a high speed circuit, check for recall work at the fan connector, etc (or a charred high speed connector - common issue).
I am not sure if this was directed at me or Rick. If Rick, it is likely a customer's car.blksn955.o said:Do you have a tweecer? I changed the fan settings to work with the 190 stat. and it fixed alot of things I was hunting around for before I tore out the tired stock shortblock. That and I have heard that the correct setting work using the tweecer helps with the det. issues common to 94-95 cars (prob. since they run so damn hot).
Well that is a little loaded then - you added timing after using a lightly modded Cobra file? That is like me saying that I run 18* base timing but that I have an A9P computer.blksn955.o said:with the fan settings set correctly, you can ADD timing I have more timing now in the upper load sections (31-32*) total and no pinging were stock with the factory 26* I was pinging like mad with 87oct or mid grade. I have heard of people going as high as 36*.
My question was geared more to rick, but yes the ability to controle the eec is well worth the learning curve and money spent on the tweecer. My eec is running a very lightly modded cobra file and so far has had little issues with the computer side of things.
Gotcha. That works.blksn955.o said:I also ran a tm4o (gt 5spd) program (using the cobras 24#inj. breakpoint/slopes and with the fan setting I ran the same timing with no pinging (I did not lean the A/F out just left it stock). I did alter the fuel and spark tables in the j4j1 (cobra calibration) to run 13.1-13.2 A/F with 32*. as stock is like close to 11:1. So loaded yes but also leaner.
Another issue seems that when people disconnect the EGR and dont have the abilty to turn off the EGR in the eec pinging starts at driving around loads. I think I read in the tweecer forums that the EGR tables have added timing (thinking there is more fuel being added from the re-circ. of the exh.) and this causes mid load/low load pinging but at WOT it should not be an issue as the EGR is turned off or not used at WOT.
