Fastest NA 4.6 2V mustang
whats a good reliable setup that will give good power and good 1/4 times....im planning on doing:
-TB and plenum
-Catback
-X-pipe
-Short Shifter
-Headers
-Gears
-Drag Radials for track
-Tune after everything is in
What kind of hp/tq will that setup give me? What kind of 1/4? Does anyone have this setup? Im hoping mid-low 13s...
The fastest N/A 2v likely holds that title due to their suspension setup. If you were to do a full engine build and were very carefull with your block and head setup/combo, you could make pretty decent power with a 4.6. A good build with the right suspension could make these cars very quick, they just need the right things.
I'd say low 13's should be easy.not high 12's,with those mods. Unless you gut the car then 12's easy. You'd need to add cams at least and maybe p&p heads on a "street" car (still has all power accessories&interior&functioning stereo) to hit 12's.
-TB and plenum
-Catback
-X-pipe
-Short Shifter
-Headers
-Gears
With 4.10s, DRs, LTs, and an O/R Mid you should be able to get into the low 13s.
Yeah, but you said it was a 5.4. All I was saying was based on Jason's post, I thought maybe the VT car was a 4.6....and I wouldn't have thought transplanting a 2v 4.6 into a fox was the best way to get power.
So the 5.4 isn't just a bored out 4.6....its a whole different engine right? Why do I feel so confused all of a sudden.
Yes the 5.4 is a Physically larger block then the 4.6 not just bored or stroked.
