f'd up!!! now what!!!
  • Thread starter Thread starter Mr. Rustypwnz
  • Start date Start date Dec 27, 2007
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Dec 27, 2007
  • Dec 27, 2007
ok ive been porting these gtp heads for a while now during christmas break, well I went a little too far!! I was working the intake port and I went into the pushrod hole, so should I sleeve it? or just weld it up and smooth it in? Im thinking sleevin would be the best. oh yeah these things are going to make power lol....
:SNSign:
jake2582
107
tallapoosa
Dec 27, 2007
  • Dec 27, 2007
you do know that if the ports are that big you will have a power band of like 5000-12,000rpm. lol.
thats if you can afford the sheetmetal intake and 2 dominators to go with it.
might need some 2.25 valves too.hahaha.
BTW: port upward and not so much out and never down!
answer to the question: epoxy works good. (a buddy had that happen with a set of BBC bowtie heads) went into the underside of the valve cover.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Dec 28, 2007
  • Dec 28, 2007
lol, naw it wont be that crazy, ill post up pics tomorrow after work. the ports are stock on the intake, just the pushrod bulges, are ground down flat(which now I know is a little too close for comfort lol) It should pull well with an xcam and 6200 rpm, on a stock bottom end... will definately be a sick street car when tuned right!!!
Im not really sure on the epoxy thing...
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Dec 28, 2007
  • Dec 28, 2007
ya me either, id say take it into a shop and have them look at it and see what an engine bulider thinks is best option to go with!
stykthyn
5,232
2,652
223
gainesville
Dec 28, 2007
  • Dec 28, 2007
weld it up with some lead and smooth it back over.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 28, 2007
  • Dec 28, 2007
This happens because the P heads pushrod hole is very close to the port wall. Use a sleeve made from thin wall brass tubing and epoxy it in place. Hobby shops will frequently have the tubing you need to do the job.
I got this tip from http://www.diyporting.com/Sleeves.html Be sure to read the article since it has some very good help. The whole website is dedicated to do it yourself porting on SBF engines.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Dec 28, 2007
  • Dec 28, 2007
Damn, that sucks. I sold a guy a Maruauder upper intakes as he ported so much that he went through the top of it. I was like man you ported it the whole thickness of the plenum, what were you thinking??
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Dec 28, 2007
  • Dec 28, 2007
oh no mine is actually controlled lol, I have a purpose not just hacking on these things. Ive got the one head completely finished as of today, just need to polish it and sleeve it, although instead of epoxy brass im going with a steel sleeve and welding it and then smoothing it down. dang ive been busy but I swear im gonna get pics up!!!
edit: after reading the diy thread, I might just do the epoxy thing, seems like it will hold up fine!!
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 20, 2025
Help! Intake Manifold Gasket or Head Gasket?
  • foxbodyclark
  • Oct 4, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
95 Laser GT Ver
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
