Few codes from KOER test...
  • Thread starter Thread starter Mike85000
  • Start date Start date May 21, 2007
M
Mike85000
65
  • May 21, 2007
Hey Guys,
Just pulled the codes on my 87GT. KOEO test came back clean, but i got a couple codes form the KOER test.
Here are the codes:
94 - Thermactor Air Injection system inoperative (left side).
44 - Thermactor Air Injection system inoperative (right side).
33 - EGR Valve opening not detected.
There isn't any emissions testing around here so I'm not super concerned. Will this have an effect on performance at all? The car is bone stock.
From what i gather the air injector pump pumps fresh air into the exhaust, and the EGR valve allows exhaust gas back into the cylinder head. Doesn't seem like it would cause a problem to me.
One day i wouldn't mind removing the smog stuff, and throwing headers and new exhaust on it.
Any thoughts,
Mike
Aryan15
236
CA
May 21, 2007
  • May 21, 2007
I'd be worried about the cats if you have them.
93 LX
3,081
Norwalk, CA.
May 21, 2007
  • May 21, 2007
I have the same codes on my 86. I changed the computer and solnoids. I have traced the wires and everything seems good. I tested the solnoids and they work just fine. I feel this will cause my car to fail So Cal smog. Anyone out there have any ideas?
Allen
M
Mike85000
65
  • May 21, 2007
Planning on removing the cats and the EGR stuff when i get new exhaust.
M
mojopony
71
  • Sep 9, 2007
My '94 GT is suffering from similar symptoms. Codes 314 & 311 (thermactor inoperative on both banks) and Code 332 (insufficient EGR flow). The EGR system is a little easier to test I think because there's less variables to deal with. The only components are the EGR valve itself, the position sensor and the vacuum regulator. These components can be tested without sophisticated equipment. The thermactor system is a little more involved and I still have to diagnose the problem on my car. I just installed a new catted H-pipe and I don't want to ruin the new cats after all that work! I have to check the operation of the solenoids and stuff to try and get a handle on what's going on.
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
C
Engine Code 94 and 13
  • CmdrDerp
  • Nov 3, 2024
Fox 5.0 Mustang Tech Nov 4, 2024
AeroCoupe
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
