Few "converting to carb" questions
tbird187
392
Indiana
Hey guys I think im going to convert to a carb setup.. I am much more familiar with tuning them ect.. really my car is not a daily driver and is more of a weekend/track car.. anyways
I have the complete aeromotive system a1000 ect.. can the regulator it comes with go down to 6-7 psi? Also Can I use the stock efi distributor with my msd 6al box??? I dont mind a locked timing since I will be running nitrous I wont have as high timing as n/a car... should be ok??? I think thats it...
A word of warning on EFI to carb swaps: don’t expect to pass emissions in any state that does comprehensive smog inspections, because it won’t happen. Be aware that you are violating several Federal laws concerning the removal of pollution control equipment. If you operate the vehicle on public highways and get caught by state or federal law enforcement (doubtful, but possible) you could be subject to fines and imprisonment. You won't get any more power from a carb than you will from EFI.
The following information is intended for informational purposes only. Operation of a motor vehicle modified in such as manner as described below should be limited to off road use only.
Doing the swap: You must know how to read electrical diagrams and wire circuits properly to do the swap. Don’t take shortcuts or cut corners in the fabrication of the electrical or mechanical assemblies. If you do NASCAR quality work, the car will look good, run good and be as reliable as a carb’d car can be. Take pride in a job done with excellence.
If you are one of those few people who do excellent work, please disregard my negative comments. They are not intended for you.
Quality, quality, quality…
Some of the motivation of my negative comments about carb to EFI has to do with the quality of electrical workmanship. A lot of the wiring “repairs” that I have seen on the road and in the junkyard looks like road kill. The other part of my negative view stems from people who can’t grasp the operation and tuning of EFI. Carbs have their own set of requirements and some learning is required to get the best performance. Every car is different and each installation needs to be tuned to get the best performance. Putting an “out of the box carb” or one from someone else’s car isn’t the way to success. There is no auto compensation for small variations in carbs like there is for EFI. Just throwing a carb on a car because you won’t bother to learn how EFI works is a poor excuse. If you are too lazy to read a book and learn how EFI works, your carb car won’t run worth beans either.
Now that the rant is over, here’s some practical advice…
Do not use an EFI in tank fuel pump with a carb. A carb requires 6-8 PSI and the EFI pump puts out 40+ PSI. You will never get the pressure/flow regulated properly. If the add on regulator fails, the resulting overpressure will flood the carb and wash all the oil off the cylinder walls. Engine seizure and death will quickly follow. Either remain EFI or use a tank/fuel pump/fuel lines out of an 84 or earlier Stang. Fabricating your own setup is possible but there are some snags to overcome.
Do not attempt to leave the EFI in place in an attempt to control either the electric fuel pump or ignition. Doing so qualifies you for the “Road Kill Mechanics Award”.
If you try to use your current tank, you will need to pull the fuel pump out and fabricate a pickup tube & strainer sock to replace the fuel pump. Or you can have a sump fabricated and welded onto you existing tank. Many welding shops will not weld fuel tanks because of the dangers involved if the tank isn't purged properly.
You will need an external electric fuel pump unless you change the timing cover for one with the mechanical fuel pump mount on it. Rip all the EFI wiring out, and the computer controlled fuel pump won't work. You will need to add a relay & switch and wire in the existing inertia switch for an external low pressure electric fuel pump. Do not try to wire the fuel pump without the relay. The 15-20 amps the pump pulls will overload the circuit. This will take power away from other items on the same circuit or cause the fuse or fuse link to blow.
attachment.php
You will need to run some new fuel feed lines or braided hose. The 3/8" aluminum tubing works well, but you will need a flaring tool and bending springs to fabricate the lines. Braided hose is easy to run and route, but is much more expensive. It is about $3.50-$4.00 a foot plus the end fittings, which are $3-$4 each. Fabricating hose assembles can be difficult, but anyplace that makes hydraulic hoses can do it for you for an extra charge. See Amazon Hose - Rubber, Hydraulic and Industrial Hose - since 1919 for more information.
For stainless steel braided hose and fittings for automotive use:
See summitracing.com
stainless steel hose - JEGS High Performance
See Eaton's Aeroquip Products for more information on High performance automotive hose products
The fancy red & blue AN fittings require a 37 degree flaring tool. A standard automotive or household plumbing tool is 45 degrees and cannot be used with AN flare fittings. If you do, the flare is subjected to too much stress when the fitting is tightened, and is likely to fail or leak.
See Industrial Supply Equipment from MSC Industrial Supply , McMaster-Carr or for the flaring tool you will need . Prices start at $81 and go up
Browse the MSC Big Book
McMaster-Carr
While you are at the electrical part, you'll need a Durspark or similar ignition system with a mechanical spark advance. The 85 Mustang GT 5 speed has a suitable Duraspark distributor with a steel gear compatible with the roller camshaft. The EFI ignition depends on the EFI sensors to advance the spark. Rip out the TPS and MAP/Baro sensors and the computer will have no idea of the proper ignition timing for best performance. Running a fixed timing setting is only for test purposes or for a race track only car. Don't try it on the street: the results will not be nearly as good as a properly setup Durspark or equal. Crane makes a really nice distributor for non-EFI applications. . See CraneCams for more information.
Tools needed:
Crimp tool for connector pins $9-$30 AutoZone, NAPA, Advance Auto Parts or other store
100-150 watt soldering gun (recommend WELLER 8200PK soldering gun kit 100/140W) $30 at Lowes or $40 at Home Depot
3/32”-1/8” rosin core electrical solder, 1/4 lb roll $6 at Ace Hardware, Home Depot or Lowes
Assorted sizes of heat shrink tubing. Buy long pieces and cut length to fit. It is cheaper that way. Parts-Express.com - Heat Shrink Index: 2:1 Ratio, 3:1 Ratio, Heat Shrink Kits
Hot air gun to shrink the tubing ($30-$40) Home Depot
Jeweler’s screwdriver kit $5 at Ace Hardware
Assorted automotive wire, 18-16 gauge 10’-20’ foot spools in different colors. $5 a roll at Advance Auto Parts.
Ford connector pins AutoZone, NAPA or other store $5-$10 for a kit of 10-12 assorted pins
You will have $110-$150 in materials and tools if you don't already have them.
The water temp and oil pressure signals feed from the sender to the main harness through the 10 pin EFI engine harness. To utilize these senders, you need to identify the wires and find a way to reconnect them to the main harness after the EFI engine harness is removed. You need a weatherproof quick connector to join the sender wiring to the main harness.
You will need to construct a wiring harness from the ‘85 carb distributor to the Duraspark box if you go Duraspark, or other distributor to coil wiring.
The voltmeter picks up its signal from the switched voltage present on the instrument panel, so you don’t need to worry about that.
The fuel tank gauge is also independent of the computer wiring.
AutoZone wiring diagrams
AutoZone.com | Get In The Zone! for 79-88 model Mustangs
AutoZone.com | Get In The Zone! for 89-93 model Mustangs
AutoZone.com | Get In The Zone! for 94-98 model Mustangs
How to solder like a pro - Ford Fuel Injection How To Solder Like a Pro a must read for any automotive wiring job.
Soldering pigtails onto existing pins is road kill quality work as far as I am concerned. Take some time to study the way the Ford connectors are assembled and you will find that a small jeweler’s screwdriver will release the pins from the connector shell. New pins and a crimping tool are available from the Standard Motor Parts or Bendix Electrical parts line that the NAPA & Bumper to Bumper Auto Parts stores carry. Ask any auto parts store about Standard Motor Products or Bendix Electrical wiring parts. Those that carry them will be able to get the parts you need. AutoZone has a cheap kit with 10 pins for about $5. Just enough pins to leave you short when assembling a connector.
One of the interesting things about the Ford OEM wiring diagrams is that the connector shape on the drawing matches the connector shape in the car. That makes it easier to identify connectors and circuits. OEM Ford diagrams are available at for an 85 Mustang at Helm Incorporated: Search Results or can be found in the Chilton series of auto repair manuals for Mustangs.
The following is an excellent idea from a fellow Stangnetter who tackled the wiring plan the right way. He obtained the wiring diagrams from an 85 carb'd V8 Mustang and laid them out side by side with the diagrams from his car. He then traced out each circuit and the wire colors and connectors associated with them. After tracing the circuit and connectors for a circuit, he laid out the changes he needed to make. One circuit at a time made a difficult big job into many smaller easy to manage jobs.
jesus what a write up anyways.. I think I could use the a1000. with a mallory 4309 regulator??? I have like -8 AN feed and return...
I am just frustrated with the efi system.... and yah Jrichker I have no emissions here.. my car has nothing to do with emissions so sorry to hurt your feelings ;)
I highly doubt the pump can be regulated down enough to be safe with a carb...the same thing goes with any typical EFI pump with a carb setup. Some people say they've done it, but i personally wouldn't.
Thinking I hsould just keep my setup I already have everything for efi Just need to work out all the bugs and get it tuned
I have a carbed setup in my 1990 GT cause I bought the car as a roller without a harness. I run the stock tank and use the stock supply line up to my frame mounted Holly red pump which is self regulated to 7 psi. I just cut the hard plastic supply line from the tank and found the right sized barbed end pipe fitting, slid the line on the hose barb and hooked it to the pump. Its a tight enough fit I dont even need a clamp, and hell it almost looks factory. From the pump upward to the motor I ran a new 3/8 fuel line and hooked it right to the carb without any issues. All you need is a Holly red pump, or a Holly blue pump with an additonal regulator. The fuel system on my car is 100% reliable and very inexpensive and easy to fix. I can send some pictures later on if you like. When I started off building the fuel system I bought some Aeromotive fuel system parts and planned on running a return and everything..... all that is completley unnecessary. Do it like I and 12 of my friends have, cheap, easy, reliable and very functional.:nice:
