  • SN95 4.6L Mustang Tech
Few problems here
  • Thread starter Thread starter Cantslowdown
  • Start date Start date Jul 29, 2006
Cantslowdown
502
Mt.Home AR!
Jul 29, 2006
  • Jul 29, 2006
Well last weekend i drove to Tulsa for a weding and i did a small burn out but right when i let off the gas the car dies..Then last night i was getting on it and it just didnt seem to pull like it normaly dose..And it didnt go all the way to its set shift point..This a auto car here b/w..
Cantslowdown
502
Mt.Home AR!
Jul 29, 2006
  • Jul 29, 2006
B/W i dont have no cel light on...Could it be a start of the IAT going bad?
Cantslowdown
502
Mt.Home AR!
Jul 29, 2006
  • Jul 29, 2006
Anyone?
the98stang
2,408
Clovis, CA
Jul 29, 2006
  • Jul 29, 2006
Maybe it's all in your head.
You could check the spark plugs, wires, fuel filter, etc
Cantslowdown
502
Mt.Home AR!
Jul 29, 2006
  • Jul 29, 2006
Thats all been changed not to long ago..
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 30, 2006
  • Jul 30, 2006
Can't really say there would be a problem unless it happened again. There seems to ba an issue with these cars dying for no appararent reason sometimes. Unless it happens again I wouldn't worry about it. You can pull a code even it the light isn't on. Wouldn't hurt to check.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 30, 2006
  • Jul 30, 2006
sounds like the fuel pump to me..
the fuel pump on our cars have a screen at the bottom of the pump housing, this screen can get filled with debris and cause the problem you are having now..
one way to test for this is to either install a fuel presure guage or use a scan tool with live data. I remember you saying you worked at a ford dealer.. have one of the techs hook up IDS/WDS and watch the pid for FPR ( fuel rail presure) and see if it drops off when you wot.. this can cause the car not to rev to redline and the loss of power.
another posibility is the rail mounted presure sensor itself is bad. thats why you should also test with a mechanical guage hooked to the fuel rail. If the mechanical guage reads much lower than the FPR then you know the FPR is gone.
Cantslowdown
502
Mt.Home AR!
Jul 30, 2006
  • Jul 30, 2006
Mike it seems to only do this when the car has been runing and is hot..
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
9
2012 Boss 302 help
  • 94blackvertgt
  • Aug 21, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 21, 2025
