  • SN95 4.6L Mustang Tech
few quick questions...
  • Thread starter Thread starter hotmustang331
  • Start date Start date Jun 23, 2006
1 of 2 Next Last
hotmustang331
2,967
Bastrop,TX
Jun 23, 2006
  • Jun 23, 2006
First off as many of you know, Im going to be installing my turbos in a few weeks. I ordered a LOT of parts last night, but have some things i am stuck on.
A. Will the lightning 90MM MAF work on a blow through setup?
B. What MAF would be best to use on my car for this setup if the lightning wont work?
C. What would running 42# injectors and a different MAF do to my A/F ratio on my way up to G.A? Safe if I dont get into boost? Or should I just keep my currect Injectors (stock) in until I get there?
D. Will a SVT focus fuel pump support 420-440RWHP W/ 42# injectors? ( already ordered it lol...but will KB BAP be needed?)
THANKS!
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 23, 2006
  • Jun 23, 2006
A) I have no idea
B) Damn you are asking some tough questions...
C) huh?
D) Yes (no but it would help)
hotmustang331
2,967
Bastrop,TX
Jun 23, 2006
  • Jun 23, 2006
Well one down Thanks mcTeague
DropTopPony
Noob Slayer
2,570
south jersey
Jun 23, 2006
  • Jun 23, 2006
i would look into the SCT 2400 or 2800 MAF's i think they have one specifically for blow through also.
you have a tune already correct? is it through a handheld or chip? if its a handheld you could have Tim email you a temp tune so you can travel lightly to him for the Dyno tune.
not sure about the HP #'s for fuel pumps for your car...mine is different...
03 Cobra TT with SCT Maf
http://www.sctflash.com/rides.php?CID=2
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Jun 23, 2006
  • Jun 23, 2006
the SVT focus fuel pumps should work on your set up.
well i really wouldnt know how much the MAF with 42# injectors change your A/F ratio with your current tune and since its quite a drive i dont know....
but here is an idea after its all bolted on leave the inlet tube disconnected form the turbos or intercooler to the T/B that way you can run your current setup up there and just swap injectors and MAF over there
the98stang
2,408
Clovis, CA
Jun 23, 2006
  • Jun 23, 2006
THANKS!
Looks like the "founding fathers" of the N/A have turned to the dark side . I wish you the best of luck with this project though. I did a TT conversion on my old Mitsu 3000GT...That thing was pretty fast.
hotmustang331
2,967
Bastrop,TX
Jun 23, 2006
  • Jun 23, 2006
^Looks like your doing a little something dark too HAHA. Good luck with yours too man
billfisher
1,296
huntsville, AL
Jun 23, 2006
  • Jun 23, 2006
to be honest, i would go to a stand alone closed loop controller and map the fuel/spark. you're going to leave 500 rwhp far behind. even with low boost. time to stop d icking around with eec(anything)
Dan_Soprano
7,410
54
129
Jacksonville, FL
Jun 23, 2006
  • Jun 23, 2006
you may want to consider going to the dual cobra pump setup for the power you will be making. The SCT BA2400 would be ideal for your setup. You may be able to get away with 42# injectors, but may want to upgrade to 60#er's for when you get your block built and really turn up the boost.
stangGT97
1,299
Boston area, MA
Jun 23, 2006
#10
  • Jun 23, 2006
  • #10
sorry i don't have answers for you.. but I do have a question. How would the stock internals hold up to a properly tuned TT setup? Just curious, all I've heard are #s for superchargers, but it seems to me a turbo may not be quite as harsh on the stock rods.
the98stang
2,408
Clovis, CA
Jun 24, 2006
#11
  • Jun 24, 2006
  • #11
Stock internals should hold up to 400WHP....that could be reached from a supercharger, nitrous, turbo's, or naturally aspirated bolt on's. I would say turbo's and superchargers put equal amounts of stress on the engine. Nitrous isn't as harsh. And cams/other bolt ons are the least stressing.
stangGT97
1,299
Boston area, MA
Jun 24, 2006
#12
  • Jun 24, 2006
  • #12
yeah, i knew that figure but didn't know if it applied to all forms of FI (excluding N2O). In my own mind, it seems like a turbo wouldn't be quite as harsh only because it does have some spool lag, whereas a SC like kenne bell is running full boost throughout the rev range. The potential of a full bolton TT car is ridiculous though, so looks like a built shortblock is in store somewhere in the future. Hotmustang, are you considering a 302BB?
QDRHRSE
1,590
Palmdale, CA
Jun 24, 2006
#13
  • Jun 24, 2006
  • #13
+1 couldn't have said it better. You will peg the Lightning MAF @ 450hp.
hotmustang331
2,967
Bastrop,TX
Jun 24, 2006
#14
  • Jun 24, 2006
  • #14
Thanks for the replys guys! Ill look into the SCT MAF....and im also looking at a C&L unit thats also used on the HP TT kit.
As far as safe HP...I look at it like this. S/Cs drag down about 60RWHP through parisitic loss.
turbos have 0 parisitic loss (maybe 15HP loss due to exhaust restriction). So equal air being pumped down the engine should put the power up to 440-460 with equal stress on the motor as a 420RWHP S/C car . I think im going to have Tim lay down at least 440.
That should definatly keep me happy the next few years lol.
jasonh_86
I
May 20, 2005
1,156
Arkansas
Jun 24, 2006
#15
  • Jun 24, 2006
  • #15
440rwhp? You lucky bastard!
You're making my 300rwhp goal look like child's play .... ****er
hotmustang331
2,967
Bastrop,TX
Jun 24, 2006
#16
  • Jun 24, 2006
  • #16
Dont forget the 500+RWTQ
hotmustang331
2,967
Bastrop,TX
Jun 24, 2006
#17
  • Jun 24, 2006
  • #17
Thanks Dan! I just picked up the BA 2400 for 238.58 shipped . I appreciate the help.
DropTopPony
Noob Slayer
2,570
south jersey
Jun 25, 2006
#18
  • Jun 25, 2006
  • #18
yeah sure thank the guy with the Cobra eventhough the guy with the GT made that suggestion 5 posts sooner Cobra guys get all the Love
hotmustang331
2,967
Bastrop,TX
Jun 25, 2006
#19
  • Jun 25, 2006
  • #19
^ Sorry I seen yours earlier, but forgot about it since I wasnt rereading the other posts LOL.
THANK YOU DROPTOPPONY! :SNSign:
jasonh_86
I
May 20, 2005
1,156
Arkansas
Jun 25, 2006
#20
  • Jun 25, 2006
  • #20
crapola :ZipIt:
Edit: You might want to change your sig, you know what's going to become of the N/A Club
1 of 2 Next Last
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
