Filling rad..need to burp system?
  • Thread starter Thread starter DMAN302
  • Start date Start date Sep 20, 2005
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Sep 20, 2005
  • Sep 20, 2005
Hey guys I need to increase the ratio of coolant in my system to protect it for winter storage (getting a jump start). Now if I open the lower valve on the rad (petcock) and allow it to start draining, then while draining...add coolant to the rad untill I have added apporox 3 quarts of coolant, do I need to burp the system..??I HATE burping the system..always make a mess and takes me forever.
9T3SVT
84
  • Sep 20, 2005
Just run the car with the heater on full blast (if you have a heater) and fill it slowly, you'll be fine doing it that way.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Sep 20, 2005
  • Sep 20, 2005
All you need to do is drain out your radiator an then refill it with your new coolant ratio. Start the car and turn on the heater. Once it comes up to operating temperature the thermostat will open and you will have to add more coolant.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Sep 20, 2005
  • Sep 20, 2005
Fan works..but the heater..nope..why exactly does the turning on of the heater assist in this.
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Sep 20, 2005
  • Sep 20, 2005
IT just cycles the coolant though your heater core so you get a good distribution of the new coolant. (if your heater core is still connected that is)
Anthony85stang
43
Meriden, CT
Sep 20, 2005
  • Sep 20, 2005
You usually can get away with not burping the system for just a drain a fill. But they sell a thing called a "spill free funnel" most reputable parts stores sell them they have a radiator cap with a hole in them and adapters and a funnel that goes on the adapter and you fill it up till a lil bit of coolant stays in the funnel and just fill it up as the thermostat opens and the coolant goes down. No mess at all.
Help! Intake Manifold Gasket or Head Gasket?
  • foxbodyclark
  • Oct 4, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
95 Laser GT Ver
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
M
  • mnky99
  • Sep 5, 2025
mnky99
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
