I went back and forth with this for a long time, finally pulled the trigger. 17x8/17x9 Pony R with 245/275 rubber. Quite happy with how she turned out!
These look really nice! I just put the exact same combo on my ‘86 GT, and with the FRPP Springs I installed to lower it a bit, it looks good.I went back and forth with this for a long time, finally pulled the trigger. 17x8/17x9 Pony R with 245/275 rubber. Quite happy with how she turned out!
Rdub6, I've attached a couple of photos below. Other than the wheels,@Willybill32 you have pics on the ‘86.
the warmed-up 5.0 and new clutch, most of my '86 is original, including the lousy original Ford paint. Once I'm satisfied with all the mechanical work, I'll look into getting a paint job.
Rdub6, I did the suspension upgrade in 2011, including upgrading to a '87-'93 front suspension for the larger discs, SSBC rear disc conversion kit, new flexible SS steel brake lines, new springs and struts/shocks on all four wheels. The springs were from FRPP (Ford Racing Performance Parts) and I believe they called for a 1-1.5" drop. I just checked the FRPP catalog and found these that I think are what I used. The description says '79-'84, but if you look, you'll see they fit an '86' .Looks nice! Don’t worry, that “patina” look is the in thing nowadays.
What drop did those springs claim to be? My ‘86 is like a 4x4. Nice to compare apples to apples (as much as it can be)
Thanks, Chris! I appreciate your favorable comment.I have always said in my opinion the right wheels and stance far outweigh the paint. I would rather drive around a primered mustang with killer rims and lowering springs than a car with shiny paint with stock 10 holes and a 4x4 look. @Willybill32 your car looks great!
Chris
Chris
