Since I bought my car it always had a funny stance. The right rear quarter sat nearly three quarters of an inch higher than the left, giving it the appearance of leaning to the left. Let it go for a long time until I finall took care of it today. In my case, the problem was the right rear coil spring was turned about an inch farther than the left side spring. Disconnected the shock and quad shock, lowered the rear end down on that side and then used a big pair of channel lock pliers to turn the coil to match the driver side. Now the difference from side to side is less than an eight of an inch.
So anyone who has the same problem, you might want to check the spring orientation. The bottom pigtails should both face the drivers side and be in the same spots.
