Nope, just fill it till the stick says it's full. Make sure you run it a little until the converter is full before you call it full.
Kurt
Kurt
One lesson I learned on an AOD, the hard way, was that you do not drain the converter completely without having some way to fill it back up BEFORE you run it. I have burnt the pump on 2 AODs before figuring that out. The AOD doesn't prime well apparently.![]()
That's good info to have. You kind of just have to run it and hope the converter pumps up before the pump burns out.
Kurt
Yes as you already know I have thought long and hard about this. My only fear is that if/when this car gets any faster I will have a hard time keeping up with the gears and lose consistency at the track.Not sure about the sensors interfering with the tranny, I thought they were just for the ABS system. You need to yank that AODE slush box out already and throw a t5 in!
