Well, here's one way.
Buy a base tweecer for $380. Now send your current chip in to Mike Glover the owner of STKR and Tweecer. He will read your chip and mail it back to you. Now he e-mails what he read off the chip and you load it into the tweecer software. Modify the tune as needed. Add 1.5 degrees timing (or if it starts knocking, back down a degree), play with the MAF curve until your a/f is to your liking (13.1), change your wot shift points, up the valve-body pressure for the 2-3 shift. You will need about an hours dyno time ($50-75) to get your a/f correct.
Also, you can alter the entire maf curve, not just globally. If you are too lean at 2000 and too rich at 5000 you can deal with that. Also you can play with part throttle shifts. I got tired of the 1-2 shift coming at 9 MPH!!!!!!!! And OD coming on at 32 unless the button was off. I fixed that easily in a few minutes.
Glad to help, I was preparing to pay ALOT of $$$$ for a dyno tune an 4 position chip (In the high $400s). My cousin and brother turned my on to TwEECer and I can do it all myself with little hassle. Now I don't mail anything in if it isn't right. I don't have to wait for the company that does dyno tunes to come to town and adjust my settings.
So $450 for a tweecer and dyno time. In the long run and short run it made sense to me.
