Finally!
  • Thread starter Thread starter ZephyrMotorspor
  • Start date Start date Jan 19, 2006
Z
ZephyrMotorspor
88
Tampa, Fl
Jan 19, 2006
  • Jan 19, 2006
Finally got it runnin. Took it down to a shop and found out i had a clogged throttle body. lol oh well. thanks for all the help though guys, jrichker and hissin50 mainly, but there were alot of electrical issues. Thanks -Jordan
HISSIN50
34
129
Jan 19, 2006
  • Jan 19, 2006
Glad you got it running. So what was the deal with no 12 volts to the injectors? Seems to me that was where you were at before.......
P
PRO50SC
1,012
Olney, Maryland
Jan 19, 2006
  • Jan 19, 2006
How in the hell do you have a clogged t/b? What was the issue? Never heard of one being "clogged" before.
HISSIN50
34
129
Jan 19, 2006
  • Jan 19, 2006
Bernie, I was thinking more like the IAC was dirty......
Z
ZephyrMotorspor
88
Tampa, Fl
Jan 21, 2006
  • Jan 21, 2006
sorry for not replying sooner, but i've been over on SVT perf. the guy (mike) said he cleaned the throttle body and it ran, however now i't won't start on nothing but ether lol. It runs like a sumbitch, well since my dad and i timed it, but only after it starts, and like i said it won't start on nothing but ether, but after it's started, it runs fine...any ideas?
p.s. hissin, i think i read it wrong. I had just a test light on the injectors. i used it also on the solenoid and the light seemed to be brighter than when i put it on the injectors, but i put a multimeter on it and found i had 12V to the injectors and 14.4 on the solenoid, so...my injectors were probably getting 12V
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 21, 2006
  • Jan 21, 2006
I know you have been through before, but do it again. Look at the last items in the checklist, especially since your repair seems to have been in the area of the throttle body.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Z
ZephyrMotorspor
88
Tampa, Fl
Jan 22, 2006
  • Jan 22, 2006
whats the ect?
vristang
4,933
101
124
Seattle
Jan 22, 2006
  • Jan 22, 2006
ZephyrMotorspor said:
whats the ect?
Engine Coolant Temperature for the eec.
It is actually different than the sensor for the dash gauge.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
