Finding Tires
Andy CobraII
52
I know everybody is stepping up to bigger size rims.
I still have 13" rims and will need to replace tires soon.
Where can I locate? What brands are available? And if I want
to increase the stance, put bigger tires on rear, what sizes do
you recommend?
thanks for suggestions
andy
Local Tire store
I guess I assumed 13" tires where getting harder to find.
I currently have cooper cobras and thought they where no
longer made. Just wondering what others where using.
Thanks for stating the obvious
I was just a a tire shop yesterday getting 2 fronts for my POS Saturn, asked about the 13s for the Mach- they said they "Might" be able to special order them, they didn't have a listing anywhere for the 195-70 13 on the Mach. They were going to call around and get back to me. They said a lot of 13' sizes are hard or impossible to find anymore, and some of the 14' sizes are starting to get that way too
looks like more $ to be spent on getting larger rims and tires to fit them :bang:
Yup...any tire not popular on front wheel drive cars is a pretty low production item.
I have a set of aftermarket 15x7 Fox wheels to play with, and there are already only a few performance tires to fit them other than the stock size of P225-60R-15.
I did find a couple of brands with P225-50R-15 tires, but none in the newer high-performance designs, and none in wider widths like P235-50R-15.
Well that sucks.
I know were not going to run those itty bitty sidewall tires, neither one of us like the looks of those on the older cars. Maybe we should buy 2 sets when we get them, that way we'll have enough to last forever.
I saw a Cadillac, ahh heck, there new SUV whatever it's called, with these huge ugly chrome wheels on it, my god it looked like chrome wagon wheels. YUCK!! :barf: :barf:
Super Star Radial GT, Winston, Cooper Cobra, and Michelin Weatherwise Sport( however Michelins are not white letter(sucks) but will last a while), and General Tire. these are some still available in my area (Virginia).
I use the same size as a II on my Honda beater, and they are getting harder to find.
Wonder if Coker Tire will / does offer them ????
I know this thread is a little old, but more info is better late than none... currently, I am running 185/70 R13 by Pirelli, the P77 's they have a nice wide tread and look sweet from behind like i have 9" wide rims.. :nice: a little smaller than stock but doesn't affect my speedo much, maybe 2mph at 60??
I need to look into getting some 14" tires for my new rims i picked up (similar to the lace style but are black have crome around the edge, that are as close to 195/70 R13 so that is doesn't f*** up my speedo, but have a nice wide tread... not something that is going to be the same size but skinny and weird looking :notnice: any sugg.?? :shrug:
You want to see something that "looks" wide? Try a P205-60R-13 on the stock wheels! :D
The general rule of thumb for maintaining tire/wheel diameter when increasing wheel diameter is to decrease tire sidewall ratio one series for each increase in diamater inches. So for a 1 inch increase from 13" to 14", decrease your sidewall ratio from 70 series to 60 series.
The trick is that 2 tires of the exact same size may have different rolling diamaters, so you'll have to measure your current tire/wheel package and compare to a chart provided by the new tire manufacturer. If you can't find the sizes on the web, the tire retailer should have them.
Here is a good tire size calculator for general information: http://www.1010tires.com/TireSizeCalculator.asp
Unfortunately, it looks like its speedometer % difference is munged up. The tire diameter % difference looks good though. Put the stock size in the upper window and your possible new sizes in the lower window and hit Calculate.
Looks like P195-60R-14 is a good equivalent to the stock P185-70R-13, but you could go to a P205-60R-14 with only 2% diamater change.
Again check the specs on the specific tire you choose for exact numbers.
