Dbeck002 said:Does anyone know what that plastic vacuum tree near the AC canistor in the passenger side engine bay is? Because 3 of 4 of those lines went to EGR and the 4th goes to the main vacuum tree B/B, A/C, B/R etc... I unplugged it from B/R and it didnt do anything. Whats it for?
Dbeck002 said:When i installed the lower i used the cork and assloads of RTV. Ive used the cork before and it worked just fine. I put sealant on all surfaces. Aroung the water jackets on the head and around the ports on the gasket. Sealant is everywhere in there.
I got her to idle, a little high but she idles.
I cleaned out the IAC and adjusted the throttle plate, she idles at around 950-1000 now but surging has been reduced. I took her for a ride and i can feel the power but she needs a tune really bad.
Dyno tomorrow!
Dbeck002 said:Yes i put RTV sealant on all sides, every axis of the three dimensions is covered with sealant. I made sure that sealant was there.
I torqued them down a little more and it helped a little. I did indeed get her to idle because i cleaned out my IAC and adjusted the throttle plate. Im happy about this and im tired at the same time. It still hasnt hit me yet that my car finally runs. i waited almost 2 whole months under the impression that it will never happen. You guys helped me out a lot too.
Thanks everyone.
