firing but won't start
latamud
791
Tampa, FL
Hello,
I was just driving the Stang down the road and forgot something so came back home. When I went to start it up again it fired for a second and died. I checked a few wire leads and even cleaned a few contacts and it still won't stay running. I tried a search and came up with nothing. Any ideas? Thanks.
Oh, I am going to post this on the VMF to get a little more coverage. I'm late for an appointment and am stranded, so please pardon me.
One possibility is that your altenator is dead, and your battery has finally been drained, and so you get a little residual charge at first, then it's gone.
Another is a bad coil maybe?
EDIT: Ok I'm a dumb bum, engine wouldn't crank if battery was dead.
You need to do a few simple tests and tell us when you fail.
1) turn key on and check for voltage at the "+" terminal on the coil. You should have9-12 volts. If you dont, pull the cap off and open the points by hand see if yo get it then.
2) crank the engine over and watch the voltage, you should still have it only it may be pulsating a bit.
3) move the meter or the test light to the "-" terminal on the coil and crank it again, this should be pulsating 12 volts on and off.
Tell us what you have and someone will set you up.
Had a similar problem a while back, it took me about a week to figure it out.
I put in a new condensor, clean up the points, and the grounds in the distributor. It work for me, hope it helps you.
I replaced the coil and the balast resistor and that took care of it. I did the balast resistor first and had same problem. After the coil it fired up and ran. Thank you all for the great responses.
