shatner saves
- Jan 13, 2004
- 583
- 0
- 0
Toney C said:Man I think with the shocks on the outside like they are that's really going to limit the width of the tires you can put on there.
I know that a lot of people put a little wider meat on there cars.
What do you guys think?
I was thinking the same thing but I don't think it'll be a problem. The lower shock/sway bar mount will acually fit inside a 17" or 18" wheel and the angle of the shocks makes it look like the upper part of the shock shouldn't be a problem either. Look at the 4th picture in the initial post. You can see the right tire tread is just visible, the lower shock/sway bar mount is visible and the shock is angled away from the tire. In the 3rd and 5th photo, on the left side, you can see that the lower mount would also clear the inside of the wheel. I'm confident a 275/40/18 with the right offset will fit no problem. Beyond that, it's risky to speculate. With the deletion of the quad shocks, there might be more room than the current design.
Overall I think it's really good design. They've moved the springs from the trailing links to the top of the axles, which means better control and the links/bushings should take less of a beating, not having to transfer the spring loads. It might also explain why the trailing links look much less beefy than they currently are. The shocks are pushed out farther, also good, and the spings and shocks are a lot closer together and more in line with each other than the current design. This means tuning the springs/shocks to each other becomes less of a "sum of vectors" deal so they should work better together throughout the range of suspension travel.
The addition of a panhard rod can only be a good thing.
The only thing I see that I might have done differently is I would have put the bump rubbers on the chassis instead of the axle. It would be minor difference in unsprung weight, but It's still a difference.
