- May 22, 2015
- 1
- 0
- 0
Ok short and long, I bought a 66 coupe with a disk brake conversion using s197 calipers in the front, 5 lig conversion all around and hideous 17inch wheels. The brakes are manual, so the huge s197 caliper he put on are kind of useless with manual brakes in my opinion. Now I got a set of 15 torque thrust d rims with new tires from a buddy Id much rather run on it but the rim doesn't clear the caliper. Now my question to all you frist Gen gurus, what factory ford caliper conversion fits for cheap? I know my 1995 gts i did 99 cobra calipers as a poor man's upgrade and all I had to do was grind the center of the caliper bracket about an 1/8 inch to make them clear properly. I know going with a crazy expensive option is easier but id much rather get a cheaper factory caliper set up. Funds are the determining factor as we all know. To me if im upgrading to wilwood, Baer or brembos im doing a entire vaccum assist booster etc. Id really like to be able to use these new torque thrust with new tires I got for free also. So with all that being said does the first Gen mustang adapt easily over to a more modern caliper set up? Thank you guys in advance for your expertise and knowledge, its greatly appreciated.
