bigcat said:
want to make a write up on how you made the liner??
First item needed is a pair of knee pads!
Yeah its easy if you are determined to make it work. It actually took 4 hours and some patience.
First go to Lowe's and see if they have the right material on a big roll. Cut a 4x9 piece or 2 4x4.5 pieces. The 4ft wide is needed to make it one piece. This material should be fairly ridgid.
My interior is black so black it was.
Take out the floor mats and throw them away.
they wont be needed no mo.
Go buy some
heavy rubber mats with large outer lip. dont ask me why just do it.
Need good snips or scissors, lay it in then envision it in place of the carpet. cut or trim it a couple of inches bigger than the area u want and remember that ur gonna want it to go under some of your other trim. make sure it curves up to the seat too, high enough to touch the seat. u can trim it later. This will be two places to use pull ties to tie to the legs of the seat. the other spot for a tie is under the dash where ur knee is. mind u ur gonna have to be crafty with those snips.
The only big slit will have to be at the corner near the gas pedal and remember to not let it interfer with the gas pedal. duh
The other corner I think I used a tie when I folded some of it together.
Dont cut a hole in the bottom for the factory mat hook
thats why I said to throw them away.
A heat gun could help but I didnt have one.
Good luck guys I'll try to get some pics later.
