First time C-clip eliminator install
  • Thread starter Thread starter JJFIVEOH
  • Start date Start date Dec 15, 2004
JJFIVEOH
263
Boca Raton, FL
Dec 15, 2004
  • Dec 15, 2004
I just got my 33-spline C-clip eliminator/axle set from Moser with a spool. I understand everything that is involved and how it goes together, but shouldn't there be something in between where the actual eliminator and rear end housing meet? I know that the ends need to be cut off so that they are flush, but it just seems to me like there should be something there to prevent leaking. Is it just me? Or is this the way it is supposed to be? Thanks.
willys1
1,004
New Jersey
Dec 15, 2004
  • Dec 15, 2004
Thats the thing with eliminators,,they leak like a b@stard!!
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Dec 15, 2004
  • Dec 15, 2004
You can use some type of gasket maker there, nothing wrong with that. Mine came with a paper gasket that I have between the two halves of the c-clip eliminators and then I have gasket-maker between the elims and the rear. No leaking on mine so far.
JJFIVEOH
263
Boca Raton, FL
Dec 15, 2004
  • Dec 15, 2004
So you probably have the Strange eliminators. The Moser are one piece. I'm not too concerned about leaking that much, it just didn't seem right to me a guess to have metal on metal with nothing in between. Since they go to lengths to make sure everything is accurate and installed perfect then to slap it together metal to metal made me think it was missing something. One other question though since we're on the subject. I'm going to use the same gear set and do not plan on taking out the pinion gear. Do the spools generally come with the same dimensions as the stock posi unit? I want to try to do this without removing the pinion gear and correctly aligning the gears by just changing sizes of the carrier shims if possible.
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Dec 15, 2004
  • Dec 15, 2004
I do have the Strange elims.
I have no idea on the setup -- I didn't do it myself.
EMW150
2,020
Roaring Spring,PA
Dec 16, 2004
  • Dec 16, 2004
Mine are Moser Brand (from about 2000) and when I installed, you weren't supposed to cut off the housing ends flush. The Eliminators had a recess cut in them that you were supposed to leave like 1/4" on the housing end which then would protrude into that recess. Maybe they've changed since then. I know with the Strange type you are supposed to cut off flush. I use RTV Ultra Black on them. They've been together for about 2 years since the last time I had it apart and no leaks.
EMW150
2,020
Roaring Spring,PA
Dec 16, 2004
  • Dec 16, 2004
You'll have to reshim the carrier but no worries with the pinion. It'll be fine. Install the carrier with the shims in their current locations and go from there. Just keep with the same overall total shim thickness to keep the same preload on your carrier bearings. You'll need an assortment of shims and a dial indicator with Mag Base. I like them set up with around .007 or .008 of backlash. Good luck with it.
JJFIVEOH
263
Boca Raton, FL
Dec 16, 2004
  • Dec 16, 2004
Thanks for the help. It shouldn't be a problem. I just need to find where I can get a shim kit. I know they exist, but everywhere I have called in the past have no clue what I am talking about. I may just buy a variety of sizes. Advanced doesn't carry them. Maybe I'll go to Circuit City. They didn't have a basic memory upgrade for my comp that I was looking for, but they had K&N's. Haha, go figure.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
M
  • mnky99
  • Sep 5, 2025
mnky99
M
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
