First time using drag tires, how much psi?
  • Thread starter Thread starter ga289stocker
  • Start date Start date Jul 8, 2006
ga289stocker
238
Sugar Hill, Ga
Jul 8, 2006
  • Jul 8, 2006
I got some 215/60/14 BFG drag radials i will be using next week. What is a recommended air pressure to began running this at? What is the lowest I should run them at as well? Car is a 65 Stang, 4sp
3050 lbs car and driver. Thanks.
thehueypilot
1,084
Medina,Tennessee
Jul 8, 2006
  • Jul 8, 2006
You could start at 18 psi and can go down to 16 psi. If you go too low (below 16 psi) the radial tire tends to loose it's ideal contact patch. Some cars with high torque can actually spin the tire around the rim if pressure is too low, but I don't think you will have to worry about that. Of course this is for drag racing and for everyday driving around town I would run at 26 - 28 psi. Good luck.
washMO66
1,000
Washington, MO
Jul 8, 2006
  • Jul 8, 2006
Not sure on a drag radial, but I use this method on a regular slick.
The best formula is to start higher PSI and find your sweet spot as it relates to hooking off the line and ET. Lower PSI will obviously help you to hook better but you will potentially lose MPH which could effect ET. You have to find your ideal happy medium which will yeild the best timeslip.
Not sure if people screw in a drag radial, never really paid attention, I have my ET Streets and my slicks screwed in to the bead as at the track my car turns the tire on the rim (or rim on the tire?) and I got tired of constantly getting out of balance.
xoxbxfx
3,959
Southlake, TX
Jul 8, 2006
  • Jul 8, 2006
drag radials are sorta meant to be run at higher psi... they are made more for street at full 35psi or so. I wouldnt go below 20psi unless you are runnin slicks.
steel1212
1,180
Frankfort, Ky
Jul 9, 2006
  • Jul 9, 2006
Lower your pressure until you have the biggest even black mark. Lower it to much and it will cup in the center and the center will be lighter. Also as you heat them up the air pressure in side will rise.
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
J
  • JRC99
  • Apr 19, 2025
JRC99
J
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
Wheels-Tires update on my Nitto Nt555 R2 Tires....
  • Mindseye007
  • May 7, 2022
3K
Fox 5.0 Mustang Tech Aug 22, 2022
96pushrod
