  • 1994 - 1995 Specific Tech
Fitment: X-Pipe & 302 VS 351W
  • Thread starter Thread starter Venom351R
  • Start date Start date Jan 19, 2008
Venom351R
4,548
41
98
MAINE
Jan 19, 2008
  • Jan 19, 2008
Im looking at getting a catted Bassani X pipe for the Mustang but will the 302 X -pipe fit on the 351W ?
I know they are two different product numbers so you would think it would not bolt up but Im having a hard time finding the X pipes for the 351W so I was wondering if for the 302 its just a direct swap?
fastgtfairlane
266
  • Jan 20, 2008
what kind of headers do you have? you might look into getting a dr gas x pipe. the reason being is that it comes in 5 pieces and is custom made for your car. im sure you can get some hi flow cats that you can weld in if you want cats with that setup. the overall design of the dr gas pipe is better than the others. it makes a little more power than other x pipes because of the placement of the crossover vs other x pipes. also, the sound from a dr gas is like no other.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jan 20, 2008
  • Jan 20, 2008
As long as you're running EFI swap headers, it's my impression that the midpipe should be the same. AFAIK, the swap headers have longer primary tubes to move the collector back into the stock position.
Venom351R
4,548
41
98
MAINE
Jan 20, 2008
  • Jan 20, 2008
Im not changing the headers that are on their now, they are made by roush and worth a lot b/c they made so few of them. I'll check into the Dr Gas pipes.
BlownFiveLiter
18
108
Chicagoland
Jan 20, 2008
  • Jan 20, 2008
I'd assume that they're 351 specific headers (shorty), so you should be good with any midpipe that will bolt to the collectors.
Venom351R
4,548
41
98
MAINE
Jan 20, 2008
  • Jan 20, 2008
correct, I was just told to never sell them b/c they are worth a lot and they are a good set of headers.
So regardless of a mid pipe being for a 94-95 5.0L it should still bolt up just fine to what I have now? I only ask b/c the mid pipe is custom made so I was not sure.
fastgtfairlane
266
  • Jan 20, 2008
go to www.drgas.com to look at their products.
S351Saleen77
423
Washington
Jan 21, 2008
  • Jan 21, 2008
I had Hooker 351 conversion short tubes and a Bassani X non cat for a 302 and it bolted right up.
I couldn't stand the sound of it though. Every time I would let off the gas to shift it sounded like I had worn out Glass Paks!! I cut the "X" out and put in a "H" and it sounded great!!
fastgtfairlane
266
  • Jan 21, 2008
what mufflers were you running. my x pipe doesnt sound like that at all.
S351Saleen77
423
Washington
Jan 21, 2008
#10
  • Jan 21, 2008
  • #10
I'm running the factory Borla's that Saleen used. I think they are the xr-1 race borla's, they are really small and loud. So the cars still sounded pretty good with cats, not too quiet. With the cats off they are pretty loud. With my car at idle next to someone with Flowmasters and no cats you can't even tell their car is running
Since my car has D.F.I. I when I let off the gas it's like a carb car it comes down real fast....not slow like with the stock computer. Thats all I could figure why it did it. Once I put a "H" In it quit doing it and sounded great!
One thing I didn't like about the Bassani was how the X was shaped. The incoming exhaust hit the X and had to split to go out ,if you know what I mean. There was not a "straight" shot for the exhaust to go out.
Fox BBK X-pipe replacement Cat?
  • TIGGER
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
AeroCoupe
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
