Five days ago I rebulid T5 tranny and now I have two problems
Well, if the engine vibrates with the clutch pedal pushed in, then the vibration is coming from your engine. With the pedal pushed in, the clutch is NOT ENGAGED!
The flywheel/pressure plate are the only things that still spin when the clutch pedal is pushed in.
Both the pressure plate and the flywheel have the 50oz imbalance to them. Meaning if you install the pressure plate or flywheel 180 degrees from where it was before, vibrations will occur.
It's the same as the driveshaft. The driveshaft is EXTERNALLY balanced, with weights on one side. Turning it 180 degrees will get the same vibrations. But since you get the vibrations with the pedal pushed in, it has to be the pressure plate/flywheel.
Scott
Here is what I find today , driver side long tube header hitting X-brace just little bit , tomorrow I ginna try put some washers under x-brace and see whats happening
And I install new hangers on H-pipe , nothing happening , have to be X-brace
I hope so :banana:
Nope , yesterday I put washers under x-brace (take me 1 hour :nonono: )and driver header doesn't touch any more x-brace but damn vibration is still there , Now I going take car back to guy who rebuild tranny
