I had crappie old plugs. Leaks from the head gasket on up. Stock heads and everything else really. Ran OK at best and would stall if I braked to hard. I would always have to tap the throttle after start up or it would stall.
I put a set of fresh gt40p heads with all the goodies, arp studs, all new gaskets, plugs, and a Systemax 2 with Holley 75mm TB. I cleaned an INSANE amount of carbon off the pistons. I mean, over an 1/8 inch thick covering the entire piston in 3 of the 8. The rest weren't this is bad, but were still bad.
I went from 21 down to 17 mpg. WTF...!?
The car now idles better, no stalling issues, and even the engine temp is steady instead of fluctuating like it use to. All in all, it's vastly improved after the work was done. But why would I lose 4mpg? I would think it would have gotten better.
Any ideas?
Any ideas?
