  • SN95 4.6L Mustang Tech
Fixing a Lean or rich Condition
  • Thread starter Thread starter Mr GT 02
  • Start date Start date May 7, 2005
Mr GT 02
548
Peabody, MA
May 7, 2005
  • May 7, 2005
See my mods below in sig....
How does one tell if he or she or Heshe is running to lean or rich?
and if u are running..lean..how can u fix this.?
A
autoXstang
  • May 7, 2005
your car might be lean due to the induction and mufflers I have similar mod and the got a dioblo tuner to tune the can for the mods I have. Money worth spent.
CanadaStang
2,093
Mb
May 7, 2005
  • May 7, 2005
You may be able to get a bit of an idea from checking the plugs, but it won't tell you if you have rich/lean "spots" the best way to tell is to get a tune, but you could get a mail order tune to correct any issues.
triggz
1,218
Gadsden, AL
May 7, 2005
  • May 7, 2005
if youre running too lean, youll often hear detonation at full throttle.. the motor will also run extremely hot if its severe (the exhaust will feel extremely hot). as for too rich (which is the way it usually goes), your exhaust will smell very strong and make you gag.. thats the biggest easiest ways to tell.
to find out for sure, go get your car on a dyno machine. they will be able to tell you your exact air/fuel ratio and give you options on how to correct it.
be prepared to spend a few hundred bucks to correct the a/f ratio properlly.
with the mods you have, your a/f is probably just fine assuming everything else is working right.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
1990 Mustang with no-start condition - Fixed and how-to
  • TTSaleen
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TTSaleen
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
