Fixing to do the Shelby Drop to my 65
Rapid
297
Columbia, SC
How much negative camber occurs from just the drop? I am just trying to work out how many, if any, shims to leave out to get the best initial setup. The car has 620 springs with a 1 inch drop.
I just did my '65. I used the 1" drop 620 springs as you are and the shelby drop. I removed 1 shim from each side (2 per control arm). I ended up with too much + camber, and when aligned, they had to add shims back. I know each car is different, but that's how it affected mine.
The specs when taken in came in at (EDIT -1.5 degrees on each side. He set it at -.2 degrees). Some people say to run 1-2 degrees with the Shelby drop, but the alignment shop didn't recommend it on radials, not to mention, 2 degrees is very noticeable to the eyes and looks rather weird.
Actually, you want negative camber in the alignment for good handling.
Somewhere around from 0 to -.5 is ideal on a street car.
Your car must plow pretty bad with +.5 camber setting :lol:
Doh, maybe it was .5- ? Can't remember now, have to check the alignment sheet. As far as plowing ??? How would .5+ cause plowing ?
EDIT- This is somewhat confusing to me, maybe because I dont' really understand it fully. But the Alignment report has Camber included twice.
It says:
Caster Left -.7
Right -.3
Camber Left .2
Right 0.0
FRONT
Toe Left 3/32
Right 3/32
Total 3/16
Camber Left -.2
Right -.2
