The only way to know is to pull a valvecover and look down the pushrod holes at the tops of the lifters. If you see them linked in pairs so they cannot rotate in the bores, then it's a roller. If you can't see down the heads, then the intake will have to come off.
Why do you suspect your "roller" engine has a flat cam?
