Flex Fans
Pbum5
515
Minneapolis, MN
Hey does anyone have any recommendations on a flex fan?
I have a 4-Row and flex fan that doesn’t do much.
It runs cool but when I am stopped in traffic for a while it can get warmer than I like.
Anyone suggestions for a better flex fan?
Make sure your fan is as close to the radiator as possible, especially without a shroud. If you have a shroud at least half the blade should be in the shroud.
I had a "high rpm" flex fan throw a blade chunk on me below 4000rpm, it cut the radiator hose and dented the hood. Imagine if it flew off while I was checking the advance on my distributor. I switched to electric. I don't want any more blades spinning at engine speed when I'm under the hood.
probably the best flex fan on the market today as far as i am concerned is the plastic ones made by flex-i-lite. they are durable, pull a bunch of air, and lightweight. that said however, i would recomend getting an electric fan from a salvage yard from a ford taurus and using that instead with a good fan controller.
2nd Mustang--
My car runs at about 175 all day long.
Just when I am stopped for a long time idling it creeps up to maybe 210.
Then if I start to drive it and get some air in there it goes right back down.
ron67fb-
throwing a blade!! You are lucky you were not working on it at the time. Maybe I should consider an Electric.
Rbohm-
Are you talking about this fan?
FLX-418
http://store.summitracing.com/defau...earchinresults=false&N=0&target=egnsearch.asp
for $17.00 it would be worth a shot.
steel1212-
which Flex-a-Lite model do you have?
Right now mine looks similar to this one.
SUM-G4940
You didn't mention how close the fan is to the radiator, and if you have a shroud or not.
You could also put a small (12" to 14") pusher electric in front of the radiator to turn on manually when you're stuck in traffic. Doesn't sound like you're overheating, just "uncomfortable". The extra pusher should be just enough for those times.
