Progress Thread Floor pan repair/build thread
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,513
2,853
234
The floor pan where the seat bolts down is cracked. This is a headache because you must remove the carpet and interior to get to the damaged area to fix it.
This is what my solution to the problem looks like:
I don't have a welder and it would have been difficult to get the car to a place that could do a satisfactory job of welding up a suitable repair..
Two pieces of 16 gauge steel that overlap at the top to make an approximately 1/8" thick hat section.
The angle sections are riveted together with monel 1/8" diameter solid rivets.
The repair is secured in place with 18 each 1/8" Cherrylock Aircraft Structural rivets.These are NOT the same as cheap Pop rivets!!! Each rivet has ashear strength of greater than 600 pounds and there are 18 rivets. The total shear strength for the riveted joint is over 5400 pounds per side. Considering my body weight, that would hold over 25 G impact for each side of the repair.
Notice that the first picture shows the damaged material cut out and the cracks are stop drilled. This keeps the cracks from spreading further and is a necessary step. This necessary even if you weld whatever repair you do in place.
037-jpg.541038
039-jpg.541039
041-jpg.541040
042-jpg.541041
044-jpg.541042
Notice the contour cut into the Rh side of the lower leg. That was done using a contour gage from Home Depot to pick up the shape of the floor pan.
47969fd4-7f99-42a3-bdbc-e6cbf0ccabe5_400-jpg.541052
Also notice the one stud for the seat that is welded in place. This is the only weld in part.
045-jpg.541043
046-jpg.541044
The studs need to hold the wiring harness in place are flat head screws that were countersunk. The heads are flush and the locknuts used to hold them in place. A little Super Glue on the threads insures that they will never come loose.
048-jpg.541045
052-jpg.541046
Here’s what the finished repair looks like
054-jpg.541047
It may be that welding the "L" shaped pieces in place one at a time would work. Cut and fit one "L", drill the bolt hole and the weld a bolt in the hole that is for the missing stud. Then weld it in place. Then repeat the cut and fit of the next "L" and weld it in place.
alutwon
36
11
18
one more thing, when I did the deadener on the doors I didn't do it on the inside. I put it on the interior outer part where the door panel is. you just have to make sure you cut holes for the bolts and such and maybe leave an access for the lock actuator. also added a better base response to the door speakers.
sav22rem22
261
34
38
037-jpg.541038
039-jpg.541039
041-jpg.541040
042-jpg.541041
044-jpg.541042
045-jpg.541043
046-jpg.541044
048-jpg.541045
052-jpg.541046
054-jpg.541047
Great write up. I was honestly lost on what to do with that. Someone had a long stud with a flat circular head on the bottom ran up through the floor to secure the seat and I kinda ignored it until now. Now I’ve got the motivation to fix it. Thanks jrichker
sav22rem22
261
34
38
Yeah that’s another reason I want to sound deaden. I do enjoy my car audio and can almost barely hear it over road noise and exhaust noise. I’ve seen some people saying they put sound deadening on the inside of the interior quarter panels. Did you do this? I may look into it
Boostedpimp
1,433
565
154
Damn looks like someone didn't want to cut open the trans whole large enough to fit the manual shifter in like they are suppose to. Autos had a smaller whole in the shifter tunnel than manuals so to do it properly your suppose to trim that whole up larger and install a transmission hump cut out of a junk manual car or buy it new from lmr. https://lmr.com/item/LRS-7277A-K/1979-93-Mustang-Manual-Transmission-Hump-Kit
Do you need the trans hump? no but you do need to cut that whole out around that shifter some.
As far as the seat stud being ripped out. that actually is pretty common with a car that has seen some light to light pulls hard and typically you need to replace that cross section https://lmr.com/item/LRS-10692/1979...DsKAE_VGrqaSOzAqzpfHPFjoy1UjLLogaAmpcEALw_wcB
but if you can clean it up you would probably be able to get by fine with this https://lmr.com/item/LRS-10692BRC-K/mustang-seat-brace-repair-kit-79-04
alutwon
36
11
18
if you mean on the plastic, no I didn't. I did put a few squares behind the window on the metal but there isn't much space and it probably didn't do much. I struggled for a few years trying to get decent audio but these cars just aren't set up for that. after the deadener I put an amp and a sub in the hatch and it I'm far happier with it now:)
sav22rem22
261
34
38
Yeah I think I failed to mention it but I actually have the tunnel hump in the house waiting to borrow a grinder with a cut off wheel so I can cut out the tunnel. The cross brace is basically ready for the seat brace repair kit but I’m just waiting for it to come back into stock I’m not sure why it’s still out of stock when they just released it like 3 weeks ago but it is a very useful looking kit.
sav22rem22
261
34
38
So one more question, I’m going to have to remove the factory sound deadening in the foot wells to uncover rust holes like I said but I am going to be putting back either noico or kilmat 80 mil. Would those be quieter than the factory sound deadening or would I be adding noise by removing it?
Boostedpimp
1,433
565
154
I've used noico and yes it will make a difference over the factory stuff.. you'll like it
Boostedpimp
1,433
565
154
Nice, yeah i've been waiting for the seat brace repair kit to get back into stock too
sav22rem22
261
34
38
Well I removed the factory sound deadening at least up to the firewall on both sides and found the rust I was looking for and…yikes..
Drivers side is worse off than the passenger side. I knew there was rust but I didn’t understand the scale of it. I’m sure worse has been fixed before. Also, the insulation on the passenger side firewall is absolutely disgusting. I guess when the heater core rotted all those years ago it soaked the insulation too. I probably need to get that mess out of my car and replace that too
General karthief
Mod Dude
Aug 25, 2016
23,731
8,774
203
I can say the Dynomat I put in the valdez did the job, it was very hot under my feet and down the trans tunnel before, the heat under this car is enough it melts the rubber seal at the shifter hole.
now it's barley warm.
  • Useful
Reactions: 1 user
