I think the price has gone up abit recently though.Great article thanks for the read...Green 94 5.0 said:buying a more expensive radiator from a different company will most likely not fix the problem. you may want to take a look at this article before you pick up and install your next aluminum radiator.....
http://www.imcool.com/articles/antifreeze-coolant/whygoodradsgobad.htm
hope that sheds some light on things or at least opens up new possibilities as to what the cause could be aside from a badly built radiator.....
gcomfx.com said:Where did you guys order the Visteon radiators from and how much more is the all aluminum one?
mytight95 said:the guy at the radiator place told me what caused it, i wasn't running the right mixture of antifreeze and water. He's a really knowledgeable guy (best around here), and told me exactly what mixture to run with a radiator that size and my motor with the heads etc.. he also said if i buy a new one, bring it up there and let him test the mixture and he wouldn't charge me. So that i wouldn't run into this problem again.
jason
