fly cutting? Changing my compression?
cantbuytime
48
My car is an 1995 50 GT, stock bore, stock pistons, stock bottom end.. the motor has been freshened up and in the process it has been zero decked.
I am going with a 2.02/1.60 valve aluminum head. I know i have to fly cut the pistons because I have .035" PV clearance.. That was checked without a head gasket.. using an E cam and 1.6 RR's but I want to use 1.7 rr's
I am also trying to get to 10.5:1 compression ratio
Now by fly cutting my pistons, I am assuming that Its going to lower my compression by a large amount..
My questions are
how do i determine how many CC's this will add by fly cutting?
How deep can i fly cut the stock piston??
when i mill my heads to make up for the valve releifs i cut, wont this make me have to fly cut the exhaust valves as well and therefor just set me right back to where i was on compression before I milled the heads??
I figured anything over 9.3:1 with stock pistons would be lucky with 60cc heads?
I am going to use the 86 HO flattops and cut valve releifs. Anyone know how to tell what cc the heads need to be to get to 10.1 compression
