Flywheel position 289 28oz
  • Thread starter Thread starter prouzicp
  • Start date Start date May 23, 2009
P
prouzicp
  • May 23, 2009
Wonder, if anybody knows how to install flywheel in correct position? I have 289 engine with 28 oz flywheel. I am doing auto trans to T5 swap and I didn´t mark position of flexplate before. Anybody can help?
zookeeper
3,415
63
109
Rogue River, Oregon
May 23, 2009
  • May 23, 2009
It'll only go on one way, the bolt holes are slightly offset.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
May 23, 2009
  • May 23, 2009
Yup, it's not possible to install with the unbalance in the wrong orientation.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
May 25, 2009
  • May 25, 2009
Be careful here, you need to make sure to use a 28oz flywheel on this motor. The motor the T5 came off of was most likely a 50oz imballance. If you are using that flyhweel then you need to have it reballanced.
P
pyroman
480
Ennis, Texas
May 25, 2009
  • May 25, 2009
Does the same apply for a flexplate on an auto? Looking at the bolt pattern it doesn't seem to be unique to any particular orientation.
zookeeper
3,415
63
109
Rogue River, Oregon
May 25, 2009
  • May 25, 2009
Same thing, only one way to get all the bolts in.
D
D.Hearne
11,730
south louisiana
May 25, 2009
  • May 25, 2009
It's even harder to get right with a flexplate if you still have the reinforcement washer that goes between the bolts and plate. As zookeeper & the others have said, all the holes line up one way, no way to get it wrong
H
1966 mustang starter and pulley troubles
  • Hotrods4ray
  • Sep 24, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
Realmongo
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
N
Vibration issue
  • Nicolaj
  • Apr 14, 2024
2K
Classic Mustang Specific Tech Nov 8, 2024
AeroCoupe
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
