  • SN95 4.6L Mustang Tech
flywheel resurfacing ? 's
  • Thread starter Thread starter jivepepper
  • Start date Start date Jul 10, 2004
jivepepper
776
Under a Sombrero. in WV.
Jul 10, 2004
  • Jul 10, 2004
I'am in the process of changing my clutch and I finally got the tranny out . I took the flywheel off and noticed some small cracks in it and I accidently broke a guide pin that is used to help hold the pressure plate on the flywheel intill tight will this mess up the balance. I plan on getting the flywheel resurfaced do you think its worth it ?
jivepepper
776
Jul 10, 2004
  • Jul 10, 2004
bump
AirWolf87
382
L I, NY
Jul 10, 2004
  • Jul 10, 2004
clutchpopper said:
bump
yeah its pretty cheap too. I had mine resurfaced when i changed my clutch because it had a few hot spots. Its about as much as getting your brake disks refaced. I payed like $50 for it, im sure it wasnt realy needed but, hell might as well do it for peace of mind.
twogts4us
4,188
12
79
Dunedin, FL
Jul 10, 2004
  • Jul 10, 2004
The FRPP billet steel replacement (the OEM is actually cast iron, so this replacement is better) is $250 list. Contact Randy over at www.modulardepot.com - parts forum. He'll likely get you a better price and can ship it to your door.
jivepepper
776
Jul 10, 2004
  • Jul 10, 2004
My flywheel is the 8 bolt and there no way to punch the guide pins out from the other side and one is broke off flush with flywheel. I will have to put a stock one back in because it less expensive . I'am also replacing the fuel pump and the front brake pads and rotors along with the clutch kit of course. Money is tight right now so I will have to settle.
twogts4us
4,188
12
79
Dunedin, FL
Jul 10, 2004
  • Jul 10, 2004
Out of curiousity, what kind of brakes are you putting on the front? I've pretty much decided on the Baer Claws (www.RPMoutlet.com for $470) and their EradiSpeed +1 on the back (which uses the stock calipers, $230 at RPMoutlet) A pretty nice setup for $700 total.
jivepepper
776
Jul 11, 2004
  • Jul 11, 2004
[/QUOTE
something cheap maybe this http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7909962155&category=33564
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
